Pins used for sample code used for Stepper + DC Motor FeatherWing
hoobay
Post by hoobay »
The sample code for the featherwing uses Adafruit_MotorShield.cpp
In this file, I see the pin mapping for a stepper motor:
    if (num == 0) {
      pwma = 8;
      ain2 = 9;
      ain1 = 10;
      pwmb = 13;
      bin2 = 12;
      bin1 = 11;
    } else {
      pwma = 2;
      ain2 = 3;
      ain1 = 4;
      pwmb = 7;
      bin2 = 6;
      bin1 = 5;
    steppers[num].PWMApin = pwma;
    steppers[num].PWMBpin = pwmb;
    steppers[num].AIN1pin = ain1;
    steppers[num].AIN2pin = ain2;
    steppers[num].BIN1pin = bin1;
    steppers[num].BIN2pin = bin2;
In the onestep() function in the same file, the AINx/BINx pins are toggled.
The sample code seems to work, in terms of the stepper motor is moving. I want to probe/monitor the AINx and BINx pins. I am trying to probe the pins numbers described in the source code above. AIN1 for example would be pin 10 for Motor 1.
I am not seeing any activity on these pins. Any suggestions on what the issue may be?
I am using this with the Feather 32u4 BLE. On pin 10/AIN1, for example, I am looking at pin "D10" as shown on the 32u4 BLE pinout.
adafruit_support_carter
Re: Pins used for sample code used for Stepper + DC Motor FeatherWing
How are you probing the pin(s)?
Please post a link to the file you are referencing.
The current Motor Shield & Wing do not directly map any pins to any motors. They use i2c to communicate with the shield.
hoobay
Post by hoobay »
This is the file that I'm referencing:
https://github.com/adafruit/Adafruit_Mo ... Shield.cpp
Around line ~497 is where pins are set. I understand i2c is used, but my guess is that the pins might also be set for debug, or portability if trying to adapt to another motor driver that doesn't use i2c.
I have a logic analyzer connected to these pins, to answer the other question.
The pins referenced are the PCA9685 pins, not the pins of the Arduino itself.
https://learn.adafruit.com/adafruit-mot ... /resources
hoobay
Post by hoobay »
Aha! That's it, thanks!
