Is there an option in circup.exe to define the name of the CIRCUITPY drive to be scanned/updated? Can it be added?
I have multiple CircuitPython devices connected to my Windows 10 PC. To keep me straight I have renamed those drives using the drive Rename option under This PC. As it is now I must rename the drive back to CIRCUITPY >> run circup.exe update >> rename the drive back to the preferred name. This is a PITA.
circup update --all --drive=MYCPDRIVE
Bruce
circup.exe option
- neradoc
Re: circup.exe option
Hi, there is the --path option to give the path or on windows I guess the letter.
You can open an issue in the circup repo with your suggestion.
https://github.com/adafruit/circup
I wrote discotool as a generic tool to find boards by name and drive name. It does more complex things than circup needs, but it will automatically find any Circuitpython board and run circup commands by passing the drive path. It can filter by drive name, board name, serial number...
It can be installed with pip.
https://github.com/Neradoc/discotool
It can do that:
You can check the name, drives and serial number by simply calling discotool.
PS D:\> circup --help
Usage: circup [OPTIONS] COMMAND [ARGS]...
A tool to manage and update libraries on a CircuitPython device.
Options:
--verbose Comprehensive logging is sent to stdout.
--path DIRECTORY Path to CircuitPython directory. Overrides automatic path
detection.
--version Show the version and exit.
--help Show this message and exit.
Commands:
bundle-add Add bundles to the local bundles list, by "user/repo"...
bundle-remove Remove one or more bundles from the local bundles list.
bundle-show Show the list of bundles, default and local, with URL,...
freeze Output details of all the modules found on the connected...
install Install a named module(s) onto the device.
list Lists all out of date modules found on the connected...
show Show a list of available modules in the bundle.
uninstall Uninstall a named module(s) from the connected device.
update Update modules on the device. Use --all to automatically
update all modules without Major Version warnings.
It can do that:
- discotool update --all
Call "circup update --all" on all detected boards, updating all libraries. - discotool install --auto
Call "circup install --auto" to install code.py requirements on all detected board. - discotool -m MYCPDRIVE update
Call "circup update" only on the board with that drive name (or any board with a drive name containing that word to be exact).
PS D:\> discotool
- CLUE nRF52840 Express
Adafruit Industries LLC [SN:880E9C9E016C]
COM3 (REPL)
- Trinket M0
Adafruit Industries LLC [SN:E0ED4F3324B02032E3841418F]
COM4 (REPL)
COM11 (DATA)
G:\ "TRINFOOT"
- blakebr
Neradoc,
Thanks for your suggestions, but not wanting to setup a full up Linux machine
I applied parts of what you said to my Windows 10 machine. All my playing came down to: This code did all I need done to a select (H:) CircuitPython machine. My libraries were WAY out of date, so it took a while to update 283 libraries.
Thanks again for pointing me in the right direction.
Bruce
circup --path H: upgrade --all
Bruce
- neradoc
I'm glad you got it solved !
Note that nothing I mentioned requires a linux machine, it all works on Windows 10.
- blakebr
Neradoc,
The installer for circup.exe sticks the executable down deep in the directory tree.To save me the suffering of tracing that path down the rabbit hole and typing each CircuitPython device's drive designation (H:) I created this Windows batch file. When saved in a convenient location where the end user can easily find it, it will go to the circup directory and update the AdaFruit devices on drives G: through P:.
C:\Users\Bruce\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\LocalCache\local-packages\Python310\Scripts
echo "CircuitPython circuip.bat file"
cd C:\Users\Bruce\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\LocalCache\local-packages\Python310\Scripts
dir
pause
circup --path G: update --all
circup --path H: update --all
circup --path I: update --all
circup --path J: update --all
circup --path K: update --all
circup --path L: update --all
circup --path M: update --all
circup --path N: update --all
circup --path O: update --all
circup --path P: update --all
dir
pause
