Exiting Rainbow Fade Loop with IR Remote
rjenn2
Post by rjenn2 »
I am having trouble exiting a loop with an IR remote.
This code is for a fading rainbow on an LED strip. The code should check the IR input during each pass of the for loop within the rainbow function. If the IR remote has received a signal from a specific button, it should turn off the LEDs.
Any feedback would be very helpful as I am very new to Arduino.
I am posting the whole code below but I believe the issue is likely in the rainbow function.
#include <IRremote.h>
#define IR_RECEIVER_PIN 6
IRrecv irreceive(IR_RECEIVER_PIN);
int inputPin = 3;
int pirState = LOW;
int val = 0;
decode_results results;
const int BorderRelay=4;
#define Border_PIXELPIN 2
#define Border_PIXELCOUNT 97 // Border
Adafruit_NeoPixel border(Border_PIXELCOUNT, Border_PIXELPIN, NEO_GRBW + NEO_KHZ800);
void setup()
  irreceive.enableIRIn();
  pinMode(inputPin, INPUT);
  border.begin();
  border.show();
  pinMode(BorderRelay, OUTPUT);
void loop()
  digitalWrite (BorderRelay, HIGH);
  val = digitalRead(inputPin);
  while (val == HIGH)
  rainbow(10);
  digitalWrite (BorderRelay, LOW);
void rainbow(uint8_t wait)
  uint16_t i, j;
  for(j=0; j<256; j++)
    for(i=0; i<97; i++)
    border.setPixelColor(i, Wheel((i*1+j) & 255));
    border.show();
    delay(wait);
    if(irreceive.decode(&results))
      Serial.println(results.value, HEX);
      irreceive.resume();
    if (results.value == 0XFD58A7)
        border.clear();
        border.show();
        break;
uint32_t Wheel(byte WheelPos)
  if(WheelPos < 85)
    return border.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  else if(WheelPos < 170)
    WheelPos -= 85;
    return border.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  else
    WheelPos -= 170;
    return border.Color(0, WheelPos * 3, 255 - WheelPos * 3);
rjenn2
Re: Exiting Rainbow Fade Loop with IR Remote
Post by rjenn2 »
Also, as you notice, this is on a motion detector. However, there is no motion when trying to turn off with the IR remote
The problem is likely due to the fact that interrupts are disabled while writing to the pixel strip, so IR transmissions during that time period will be missed.
Depending on which processor you are using, you may be able to avoid the issue by using DMA to write to the pixels: https://learn.adafruit.com/dma-driven-neopixels
Return to “Arduino”
