Continued thanks to all the folks on this forum who are so responsive and helpful, most appreciated.
Just a simple question - is there any chance of getting alarms.sleep_memory implemented on the Raspberry Pi Pico?
SleepMemory on Pico?
- bidrohini
Re: SleepMemory on Pico?
It is possible to implement the alarms.sleep_memory function on the Raspberry Pi Pico, but it would likely require writing custom code to interface with the Pico's hardware. The Pico uses a different microcontroller than the standard Raspberry Pi, so the exact implementation details would depend on the specific libraries and programming languages in use.
- BooleanMattock
I'm sure you're right, but since the RP2040 is in widespread use, presumably similar code could be used for other boards using the same processor.bidrohini wrote: ↑Fri Jan 27, 2023 9:07 am It is possible to implement the alarms.sleep_memory function on the Raspberry Pi Pico, but it would likely require writing custom code to interface with the Pico's hardware. The Pico uses a different microcontroller than the standard Raspberry Pi, so the exact implementation details would depend on the specific libraries and programming languages in use.
In DORMANT mode, the RP2040 preserves static RAM contents, so I assume it's just a matter of reserving a small dedicated area of RAM that is not initialized on an alarm-restart.
- BooleanMattock
OK, maybe I should just try to implement it myself.
Can anyone point me to the code I'd need to modify?
Many thanks.
Many thanks.
