I'm trying to get set up with the MS8607 sensor on a Raspberry Pi Zero W. I've followed this guide https://learn.adafruit.com/circuitpytho ... spberry-pi to get it set up with CircuitPython / Blinka and then run
sudo pip3 install adafruit-circuitpython-ms8607
However, when I try importing the adafruit_ms8607 module in python3 I get the following error:
Code:
import board
import busio
from adafruit_ms8607 import MS8607
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.9/dist-packages/adafruit_ms8607.py", line 38, in <module>
from micropython import const
ImportError: cannot import name 'const' from 'micropython' (/usr/local/lib/python3.9/dist-packages/micropython.py)
Thanks for any help!
