Raspberry Pi 4B Doesn't Boot
talmax
Post by talmax »
Hello, so I got this raspberry pi 4B from you today When I installed raspberry pi os, and inserted the sd card and turned it on, there is no display. I tried changing the config file but still nothing. Any tips to make it show. I only see the red light. I believe I have a damaged board. It does not boot. I've tried all troubleshooting steps.
adafruit_support_carter
Re: Raspberry Pi 4B Doesn't Boot
Did you try getting the Pi to boot before adding the fan and heat sinks?
https://learn.adafruit.com/raspberry-pi ... this-first
talmax
Post by talmax »
Hello, Carter. Yes, I have. I have tried with a different SD card and a different power supply
talmax
Post by talmax »
adafruit_support_carter wrote: Wed Jan 25, 2023 1:48 pm Did you try getting the Pi to boot before adding the fan and heat sinks?
talmax
Post by talmax »
Could you do a replacement?
If the Pi did not boot prior to attaching the fan and heat sinks, why were they then added?
talmax
Post by talmax »
I saw it power up didn't attach anything then attached everything and thats when i realized that it was not booting. Don't know what you are accusing or coming from but I would like a replacement
talmax
Post by talmax »
I would just like a replacemment.
As support, if an item isn't working it should be refunded or replaced as per adafruit policy.
If you could send me an email for the replacement even better.
In general, anything attached to a Pi's GPIO pins is considered warranty voiding:
https://learn.adafruit.com/raspberry-pi ... ng/warning
If you disconnect the fan and try this check:
https://learn.adafruit.com/raspberry-pi ... ck-3110723
what behavior do you see?
talmax
Post by talmax »
Hello, it just flashed green one time for a millisecond and it disappears. Doesn't do anything else. I initially tried powering it on without any accessories like mentioned before. It just stays at Red. So, it wasn't cause of the fan.
I would really like to not have any more complications, and ask for a replacement.
talmax
Post by talmax »
talmax wrote: Fri Jan 27, 2023 1:10 pm Hello, it just flashed green one time for a millisecond and it disappears. Doesn't do anything else. I initially tried powering it on without any accessories like mentioned before. It just stays at Red. So, it wasn't cause of the fan.
I tried every troubleshooting step, and no progress. I've tried it without the case, with the case, with the SD Card, Without the SD Card. I even tried with a different SD Card, and a different power supply, and so, really all I need is a replcement to have a functional raspberry pi.
If this is something that is not possible. I would like to elevate the case, because it is not users fault rather raspberries / the vendor.
Replacements are not possible due to inventory shortages. We can only offer a refund.
Send an email to [email protected] with a link to this thread and your order number and they can refund you for the Pi.
Return to “Adafruit Raspberry Pi® accessories”
