Macropad CPY drive corrupting itself regularly
dearmash
Post by dearmash »
Info_UF2
UF2 Bootloader v2.0
Model: Raspberry Pi RP2
Board-ID: RPI-RP2
boot_out.txt
Adafruit CircuitPython 7.3.3 on 2022-08-29; Adafruit Macropad RP2040 with rp2040
Board ID:adafruit_macropad_rp2040
I'm effectively running the stock demo from https://learn.adafruit.com/macropad-hot ... oject-code with customized macros and I'm running into the issue if I disconnect / reconnect my device, the lib/ and macro/ folders get corrupted in a way that they just show up as 0 byte executable files to my OSX machine.
Strangely enough, the code.py is not affected by this. It does mean though that every so often I need to delete the empty files, and reupload them to the device from my computer. After losing them a few times now, I finally have backups.
I haven't run into this issue for the first long while since getting it in the Adabox. It's happened to me now at least 4 times since the new year. Not sure if there's any additional info I can give, or debugging steps you can provide
neradoc
Re: Macropad CPY drive corrupting itself regularly
Post by neradoc »
Could you have some new software or some update that accesses the drive ?
What version of the OS is running ?
Have you tried disabling the USB drive ? I use something like that, to put in a boot.py file, which makes the drive hidden, and only appear when you hold the first key down when the board boots, if you want to make modifications.
import board
import digitalio
import storage
key1 = digitalio.DigitalInOut(board.KEY1)
key1.switch_to_input(digitalio.Pull.UP)
if key1.value: # not pressed
    storage.disable_usb_drive()
dastels
Post by dastels »
Are you ejecting cleanly before disconnecting?
