I am trying to use Adafruit Braincraft hat on a raspberry 4 to run tensor flow. After solving some issues with help from Adafruit support, I made it to the tensor flow installation here:
https://learn.adafruit.com/running-tens ... ow-2-setup
All installation commands executed without an error message.
RELEASE=https://github.com/PINTO0309/Tensorflow ... arch64.whl
CPVER=$(python --version | grep -Eo '3\.[0-9]{1,2}' | tr -d '.')
pip install $(echo "$RELEASE" | sed -e "s/cp[0-9]\{3\}/CP$CPVER/g")
I thought this last command should be pip3 rather than pip. I tried both with the same result: no error messages when installing, but the same error messages when executing the test program
Note: The camera and the Braincraft display are both working well.
Here are the last two commands of the installation:
restrepo@braincraftpi:~ $ cd rpi-vision/
restrepo@braincraftpi:~/rpi-vision $ python3 tests/pitft_labeled_output.py --tflite
pygame 2.1.2 (SDL 2.0.16, Python 3.9.2)
Hello from the pygame community. https://www.pygame.org/contribute.html
/home/restrepo/.local/lib/python3.9/site-packages/tensorflow_io/python/ops/__init__.py:98: UserWarning: unable to load libtensorflow_io_plugins.so: unable to open file: libtensorflow_io_plugins.so, from paths: ['/home/restrepo/.local/lib/python3.9/site-packages/tensorflow_io/python/ops/libtensorflow_io_plugins.so']
caused by: ["[Errno 2] The file to load file system plugin from does not exist.: '/home/restrepo/.local/lib/python3.9/site-packages/tensorflow_io/python/ops/libtensorflow_io_plugins.so'"]
warnings.warn(f"unable to load libtensorflow_io_plugins.so: {e}")
/home/restrepo/.local/lib/python3.9/site-packages/tensorflow_io/python/ops/__init__.py:104: UserWarning: file system plugins are not loaded: unable to open file: libtensorflow_io.so, from paths: ['/home/restrepo/.local/lib/python3.9/site-packages/tensorflow_io/python/ops/libtensorflow_io.so']
caused by: ['/home/restrepo/.local/lib/python3.9/site-packages/tensorflow_io/python/ops/libtensorflow_io.so: cannot open shared object file: No such file or directory']
warnings.warn(f"file system plugins are not loaded: {e}")
xcb_connection_has_error() returned true
File "/home/restrepo/rpi-vision/tests/pitft_labeled_output.py", line 32, in <module>
screen = pygame.display.set_mode((0,0), pygame.FULLSCREEN)
pygame.error: No available video device
restrepo@braincraftpi:~/rpi-vision $ echo $DISPLAY
:0
What am I doing wrong?
braincraft tensor flow unable to load libtensorflow_io_plugins.so
- pjrestrepo
