SHT40 Breakout for high RH% environment
- AndrewPak
I ordered an SHT40 to monitor and regulate humidity in an 80-89% humidity grow environment. I'm concerned about sticking the entire breakout board in the grow space. The constant high humidity without any breaks is probably going to corrode the components on the board. I've been thinking about screwing it onto a wall of a waterproof PCB enclosure and drilling an extra hole where the sensor can be exposed to the air. How would make sure that none of the high humidity air makes it through the hole? Is it safe to use silicone caulking or a hot glue gun to seal the gaps?
- mikeysklar
Re: SHT40 Breakout for high RH% environment
The SHT40 datasheet mentions a littlebit about their own protective design.
https://cdn-learn.adafruit.com/assets/a ... 1673387912
It also gets into recommended operating conditions in which > 80% will start to skew humidity readings.
2.3 Recommended Operating Conditions
Figure 13. SHT45 typical and maximal temperature accuracy.
The sensor shows best performance when operated within the recommended normal temperature and humidity range of 5 °C ... 60 °C and 20 %RH ... 80 %RH, respectively. Long term exposure to conditions outside recommended normal range, especially at high relative humidity, may temporarily offset the RH signal (e.g. +3 %RH after 60 h at >80 %RH). After returning into the recommended normal temperature and humidity range the sensor will recover to within specifications by itself. Prolonged exposure to extreme conditions may accelerate ageing.
- AndrewPak
Thanks. It's my understanding that using conformal coating is tricky and requires proper baking to get it right. How could I do this at home? Now, I don't need this thing to give me accurate readings for years. I'm happy to replace any RH sensor over time, but I'm more concerned about the board not lasting very long due to the humidity.
The SHT4x have a programmable heater that can supposedly keep it functioning well in condensing environments. And I'm not too worried about drift of 3%. My main concern is keeping the board intact. Can I mount the board with the sensor to the outer wall of my environment and then make a hole right where the sensor is? And then make a seal around it with some kind of epoxy?
- mikeysklar
Only exposing the sensor to the inner environment while mounting the board externally. You can probably make use of the air gap this board features around the sensor itself to help further enclose the sensor with some 1/4" tubing maybe?
- adafruit2
this sensor has a PTFE cover
https://www.adafruit.com/product/2857
