8.0.0-beta.6 on 2022-12-21 defaults
blakebr
Post by blakebr »
Good Afternoon,
My code.py file has the following in it:
# code.py selector
import time
import supervisor
import microcontroller
CODE = 'pin_scan.py'
time.sleep(1)
supervisor.set_next_code_file(CODE)
supervisor.reload() # Ctrl-C then Ctrl-D
pin_scan.py has the following in it:
import time
import board
from   digitalio import *
All other code in both files is commented out with:
Stuff
Ctrl-C gives me:
Adafruit CircuitPython 8.0.0-beta.6 on 2022-12-21; Raspberry Pi Pico W with rp2040
The RPi Pico W is mounted on a Maker Pi Pico Rev1.2 chassis.
After power has been removed and restored and the small bit of code(s) are run:
1) pins 6, 7, 8, 9, 15, 16, 17, 20, 21, 22 are shown as high by the LEDs on the chassis.
2) The LED on the Pico W flashes every 5 seconds.
3) If I set GPIO pins to a state other than the one in 1) they are returned to the state in 1) at the end of the code run.
Are there things in the OS or the supervisor code that would cause this behavior?
Bruce
danhalbert
Re: 8.0.0-beta.6 on 2022-12-21 defaults
Post by danhalbert »
3. At the end of each virtual-machine run (when the CircuitPython program terminates), the pins are reset to floating.
1. Are your LEDs connected directly to the pins, or are the connected to some LED driver that might see floating as HIGH?
2. The LED flashing every 5 seconds means CircuitPython is running. If you do a reload your code. py is running over and over (and doing a reload each time).
blakebr
Post by blakebr »
Dan,
1) The Maker Pi Pico board may well have pull-up resistors on those pins on the board. Solved.
2) So code.py keeps looping in the background doing much of nothing but flashing the LED every 5 seconds. The code.py has instructions to run pin_scan.py but it does not do that. There are no instructions in code.py to flash the LED but it does that. There is nothing sent to REPL during this time. So CircuitPython just sits in the corner flashing the LED every 5 seconds waiting for a file read/write or a Ctrl-D from the keyboard. Is the flashing LED a new function of CircuitPython or one I have missed noticing for years.
I know that if I send a new file the code.py is re-interpreted/re-compiled then excited. If I hit Ctrl-D does CircuitPython re-interpret/re-compile or does it use what is already in the code buffer? Your answer may solve some behavior I have seen. Does CircuitPython do a pre-interpret and then process the tokenized result, or does it interpret the raw ASCII text as it goes along each time.
The behavior is: code.py runs and then loads pin_scan.py with supervisor.reload(). If I have not edited either file and pin_scan.py has focus. If I hit Ctrl-S while in the editor, pin_scan.py reruns not code.py.
Bruce
danhalbert
blakebr wrote: Sun Jan 29, 2023 3:42 pm Dan,
Good. That makes sense.
It has been this way since 7.0.0. It used to use a solid color or pulsing LED, but that used more power and was more distracting. Details of what the LED behavior: https://learn.adafruit.com/welcome-to-c ... ht-2978455
Each time you do a soft-reload, it re"compiles" (converts to byte code) the text program.
CircuitPython doesn't know what's going on the editor. All it knows is that some file changed. So it does an auto-reload. Your code.py runs, and then it forces a reload after specifying pin_scan.py should run next, so it runs pin_scan.py on the reload. If you put print statements at the top and bottom of code.py and pin_scan.py, I think what is happening will become clearer.
danhalbert
The status indications do not monopolize the use of the RGB LED. If you use it yourself, with board.NEOPIXEL, etc., the status indications will not be shown.
