Hi
After having worked since years with Arduino, I want to go over to a microcontroller system with more memory, more compact and with less wires between modules. So I want to test the Feather system.
I have an "urgent" project (urgent = < 6 months for a full working prototype).
It's a magnetometer giving the horizontal and vertical components of the earth magnetic field and also the location. The objective specs are :
dimensions (without battery) : max 6x8x12 cm
must have :
a microcontroller (of course)
a SD Card (micro SD)
a RTC
a magnetometer (like a HMC5883 or better)
an inclinometer (gyroscope and/or accelerometer)
a display (240x160 is fine)
a GPS
Is that possible ? With which Feather modules ? (to be honest, I have no knowledge about Feather)
Jacques
Magnetometer project
- sj_remington
Re: Magnetometer project
All that is possible, even straightforward. There are plenty of tutorials covering each aspect of the project.
Consumer grade magnetometers need to be carefully calibrated for scale and offset on each axis, plus hard and soft iron distortion. Tutorial: https://thecavepearlproject.org/2015/05 ... r-arduino/
Tilt can be measured with a consumer grade accelerometer (not a gyro).
Note that the HMC5883 was discontinued years ago, and you can now buy 9DOF modules with much better specifications, which have both the magnetometer and the accelerometer. That saves you the trouble of aligning them.
