CircuitPython USB Audio
ihab
Post by ihab »
Hi folks,
Is there a way to support USB Audio via CircuitPython, writing to the DAC on the microcontroller (where this is supported in hardware)? My ItsyBitsy M4 shows up with:
C:  #Ifs= 6 Cfg#= 1 Atr=80 MxPwr=100mA
I:  If#= 0 Alt= 0 #EPs= 1 Cls=02(commc) Sub=02 Prot=00 Driver=cdc_acm
E:  Ad=81(I) Atr=03(Int.) MxPS=  64 Ivl=16ms
I:  If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_acm
E:  Ad=02(O) Atr=02(Bulk) MxPS=  64 Ivl=0ms
E:  Ad=82(I) Atr=02(Bulk) MxPS=  64 Ivl=0ms
I:  If#= 2 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E:  Ad=03(O) Atr=02(Bulk) MxPS=  64 Ivl=0ms
E:  Ad=83(I) Atr=02(Bulk) MxPS=  64 Ivl=0ms
I:  If#= 3 Alt= 0 #EPs= 2 Cls=03(HID  ) Sub=00 Prot=00 Driver=usbhid
E:  Ad=04(O) Atr=03(Int.) MxPS=  64 Ivl=8ms
E:  Ad=84(I) Atr=03(Int.) MxPS=  64 Ivl=8ms
I:  If#= 4 Alt= 0 #EPs= 0 Cls=01(audio) Sub=01 Prot=00 Driver=snd-usb-audio
I:  If#= 5 Alt= 0 #EPs= 2 Cls=01(audio) Sub=03 Prot=00 Driver=snd-usb-audio
E:  Ad=05(O) Atr=02(Bulk) MxPS=  64 Ivl=0ms
E:  Ad=85(I) Atr=02(Bulk) MxPS=  64 Ivl=0ms
but despite snd-usb-audio, it doesn't show up in my OS as a sound card.
Ihab
mikeysklar
Re: CircuitPython USB Audio
Post by mikeysklar »
I don't think I've seen this type of usage before. Are you trying to use your ItsyBitsy M4 as a USB Audio device when plugged into a linux box? If so, I don't see a way to do that.
You can write audio files to the DAC, but the code would have to be loaded onto the ItsyBitsy M4 something like this:
import time,random,board
from audiocore import WaveFile
from audioio import AudioOut as AudioOut # only DAC
wave_file = open("laser20.wav", "rb")
wave = WaveFile(wave_file)
audio = AudioOut(board.A0)  # must be DAC-capable pin, A0 on QTPy Haxpress
while True:
  print("audio is playing:",audio.playing)
  if not audio.playing:
    audio.play(wave)
    wave.sample_rate = int(wave.sample_rate * 0.90) # play 10% slower each time
  time.sleep(0.1)
https://learn.adafruit.com/todbot-circu ... ac-3113967
danhalbert
Post by danhalbert »
The "audio" USB device stuff you see is really MIDI, not regular audio. MIDI support in USB is part of audio support.
ihab
Post by ihab »
That was my hope. :) Thank you for the info!
Got it.
Thanks everyone,
Ihab
