Read 8 pins in parallel into a byte
- andor8
Parallel port on CLUE. On the Arduino UNO I can read the value of all 8 pins for port B by using the defined PORTB (int dataB = PORTB;). How is a similar operation possible on the CLUE?
- andor8
Re: Read 8 pins in parallel into a byte
.. and to clarify - that is programming the CLUE in C using Arduino IDE
- westfw
It'd look like:
Beware that bits are relatively scrambled, and some of the are in NRF_P1 rather than P0
uint32_t port0Pins = NRF_P0->IN;
