Music Maker Shield - Record Ogg Example - VS1053 not found
ID1234
Post by ID1234 »
I am using an Arduino Uno and the Adafruit music maker shield.
I have managed to get the 'player_simple' example from the Adafruit VS1053 Library to work, however I am having issues with the 'Record_ogg' example.
Get the printout:
Adafruit VS1053 Ogg Recording Test
VS1053 not found
  This is an example for the Adafruit VS1053 Codec Breakout
  Designed specifically to work with the Adafruit VS1053 Codec Breakout
  ----> https://www.adafruit.com/products/1381
  products from Adafruit!
// This is a very beta demo of Ogg Vorbis recording. It works...
// Connect a button to digital 7 on the Arduino and use that to
// start and stop recording.
// A mic or line-in connection is required. See page 13 of the
// datasheet for wiring
// Don't forget to copy the v44k1q05.img patch to your micro SD
// card before running this example!
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// define the pins used
#define RESET 9      // VS1053 reset pin (output)
#define CS 10        // VS1053 chip select pin (output)
#define DCS 8        // VS1053 Data/command select pin (output)
#define CARDCS A2     // Card chip select pin
#define DREQ 3       // VS1053 Data request, ideally an Interrupt pin
#define REC_BUTTON A0
Adafruit_VS1053_FilePlayer musicPlayer = Adafruit_VS1053_FilePlayer(RESET, CS, DCS, DREQ, CARDCS);
File recording;  // the file we will save our recording to
#define RECBUFFSIZE 128  // 64 or 128 bytes.
uint8_t recording_buffer[RECBUFFSIZE];
  Serial.begin(9600);
  Serial.println("Adafruit VS1053 Ogg Recording Test");
  // initialise the music player
  if (!musicPlayer.begin()) {
    Serial.println("VS1053 not found");
    while (1);  // don't do anything more
  musicPlayer.sineTest(0x44, 500);    // Make a tone to indicate VS1053 is working
  if (!SD.begin(CARDCS)) {
    Serial.println("SD failed, or not present");
  Serial.println("SD OK!");
  // Set volume for left, right channels. lower numbers == louder volume!
  musicPlayer.setVolume(10,10);
  // when the button is pressed, record!
  pinMode(REC_BUTTON, INPUT);
  digitalWrite(REC_BUTTON, HIGH);
  // load plugin from SD card! We'll use mono 44.1KHz, high quality
  if (! musicPlayer.prepareRecordOgg("v44k1q05.img")) {
     Serial.println("Couldn't load plugin!");
     while (1);
uint8_t isRecording = false;
  if (!isRecording && !digitalRead(REC_BUTTON)) {
    Serial.println("Begin recording");
    isRecording = true;
    // Check if the file exists already
    char filename[15];
    strcpy(filename, "RECORD00.OGG");
    for (uint8_t i = 0; i < 100; i++) {
      filename[6] = '0' + i/10;
      filename[7] = '0' + i%10;
      // create if does not exist, do not open existing, write, sync after write
      if (! SD.exists(filename)) {
        break;
    Serial.print("Recording to "); Serial.println(filename);
    recording = SD.open(filename, FILE_WRITE);
    if (! recording) {
       Serial.println("Couldn't open file to record!");
       while (1);
    musicPlayer.startRecordOgg(true); // use microphone (for linein, pass in 'false')
  if (isRecording)
    saveRecordedData(isRecording);
  if (isRecording && digitalRead(REC_BUTTON)) {
    Serial.println("End recording");
    musicPlayer.stopRecordOgg();
    // flush all the data!
    // close it up
    recording.close();
    delay(1000);
uint16_t saveRecordedData(boolean isrecord) {
  uint16_t written = 0;
    // read how many words are waiting for us
  uint16_t wordswaiting = musicPlayer.recordedWordsWaiting();
  // try to process 256 words (512 bytes) at a time, for best speed
  while (wordswaiting > 256) {
    //Serial.print("Waiting: "); Serial.println(wordswaiting);
    // for example 128 bytes x 4 loops = 512 bytes
    for (int x=0; x < 512/RECBUFFSIZE; x++) {
      // fill the buffer!
      for (uint16_t addr=0; addr < RECBUFFSIZE; addr+=2) {
        uint16_t t = musicPlayer.recordedReadWord();
        //Serial.println(t, HEX);
        recording_buffer[addr] = t >> 8;
        recording_buffer[addr+1] = t;
      if (! recording.write(recording_buffer, RECBUFFSIZE)) {
            Serial.print("Couldn't write "); Serial.println(RECBUFFSIZE);
            while (1);
    // flush 512 bytes at a time
    recording.flush();
    written += 256;
    wordswaiting -= 256;
  if (!isrecord) {
    Serial.print(wordswaiting); Serial.println(" remaining");
    // wrapping up the recording!
    uint16_t addr = 0;
    for (int x=0; x < wordswaiting-1; x++) {
      // fill the buffer!
      if (addr > RECBUFFSIZE) {
                Serial.println("Couldn't write!");
                while (1);
          recording.flush();
          addr = 0;
    if (addr != 0) {
      if (!recording.write(recording_buffer, addr)) {
        Serial.println("Couldn't write!"); while (1);
      written += addr;
    musicPlayer.sciRead(VS1053_SCI_AICTRL3);
    if (! (musicPlayer.sciRead(VS1053_SCI_AICTRL3) & (1 << 2))) {
       recording.write(musicPlayer.recordedReadWord() & 0xFF);
       written++;
    recording.flush();
  return written;
Note that I've changed the card chip select pin from A0 to A2 and the record button from 7 to A0. (I want to incorporate the recording function into an existing program that has A0 as a button.)
Circuit photos.
(A0, GND, M- and M+ soldered on underside of board)
Any advice gratefully received, very new to this.
mikeysklar
Re: Music Maker Shield - Record Ogg Example - VS1053 not found
Post by mikeysklar »
Can you go over the soldering again? The shape of the solder points is look as though a little more heat is required to get a full connection. Are all the jumper wires also soldered?
If possible I would try to start with the default pinout, get the example code running and then start changing the pins.
