I have a Clue that I am trying to connect to a mouse. The BLE Gatt for HID devices indicates there is some message that has bits for left, middle, and right buttons as well as x and y coordinates of the mouse. I want to read that message to be able to track the distance I have moved the mouse and to use the mouse buttons as an input device for the clue. I've search Github for examples and the one I need:
https://github.com/adafruit/Adafruit_Ci ... central.py
doesn't work.
Following other examples, I've been able to scan for peripherals and find the mouse I am using and connect to it, but I can't figure out how to get the list of services, characteristics, reports... Whatever element that contains the data from the mouse.
Has anyone else tried this? Any pointers would be appreciated.
Read coordinates from a BLE Mouse
- FriehoffT
Re: Read coordinates from a BLE Mouse
Just for your info: I am also very interested to have a code sample that shows how to be a BLE Central in CP
Thomas
Thomas
- tshippy
I've made a little progress using the ble_json_central.py example on github. I modified the uuids in the ble_json_service and it now uses the mouse uuid to create a connection. However it throws an error when it calls the _discover_remote function in the BLEConnection object. Specifically this line:
results = self._bleio_connection.discover_remote_services((uuid.bleio_uuid,))
throws this error:
File "code.py", line 26, in <module>
File "/lib/adafruit_ble/__init__.py", line 107, in __getitem__
File "/lib/adafruit_ble/__init__.py", line 70, in _discover_remote
ConnectionError: Not connected
That shouldn't be happening because that call comes right after this check in the main module:
if connection and connection.connected:
I suspect I need to pair the devices instead of (or in addition to) connecting them. Or maybe there is some additional step to establish an encrypted connection to a mouse.
I'm happy to post all my code if anyone else is looking at this. I have a lot of years programming, but I'm new to python and BLE and I suspect I am overlooking something relatively simple.
throws this error:
