ESP32S2 TFT Feather
- Fc3sunfire
ESP32S2 TFT Feather
I purchased this on 1/25 and it appears DOA. I have used 2 different USB-C cables and tried connecting a battery as well all did not help. I am requesting ideally a new product, but would take a refund if no others exist
- Attachments
- image.jpeg (240.31 KiB) Viewed 129 times
- image.jpeg (266.38 KiB) Viewed 129 times
- adafruit_support_carter
Re: ESP32S2 TFT Feather
What is your indication that is DOA? Have you tried programming it?
- Fc3sunfire
Yes. My indication is that it does not connect or show in the Arduino IDE. I have the correct ESP32 board and have the other version of this board that works perfectly. I tried 2 different USB-C cords to connect and no luck. It does not ever appear in the Ports section. I tried to press Reset on the board multiple times.
Please advise.
Please advise.
The guide for the reversed version of the ESP32-S2 TFT Feather is currently in works. That guide will have more details about getting the board setup, etc. It'll likely require some slightly different steps than the "other" (non-revered) ESP32-S2 TFT Feather.
For now, try holding the D0 button while pressing the Reset button. That should put the board in ROM bootloader mode. Nothing will show on the TFT, but you should hopefully see a COM port show up on your PC.
- Fc3sunfire
Worked great! Thanks, glad not really defective. Need anyone to test the new write-up for the board?
Glad it's working now. That process got it into ROM bootloader mode, which is a general fail safe fallback. And should always be able to get into that mode to recover from any weird state the board may get into. Next steps depend on how you want to program the board. That's the details the guide will cover.
I'll try and remember to post a link to the guide here when it goes live. All guides have a "feedback" link - look in the left hand navigation menu items. So definitely checkout the guide and use the feedback for anything. That way it'll go direct to the guide author(s).
