Raspberry Pi Motor HAT
Idk827378292
Post by Idk827378292 »
If I use the stacking headers for the motor hat, could I control servos separately using them?
adafruit_support_carter
Re: Raspberry Pi Motor HAT
Do you mean via the Pi's GPIO pins and not via the HAT?
You can use the schematics here to determine what GPIO pins are used by the HAT:
https://learn.adafruit.com/adafruit-dc- ... /downloads
Idk827378292
Yes, I am talking about the pi's gpio pins and if I can still use them if I use the extra tall headers.
Using stacking headers, all the pins are accessible on the header. In any case, most of the pins are also available via the labeled breakout holes that run parallel to the header.
The HAT itself is an i2c bus device and only uses SDA and SCL. These pins can be shared with other i2c devices.
OK, sure, in general you could do that. Just use the above docs to make sure not to interfere with pins being used by the Motor HAT itself.
Also note there is a separate row of header pads on the Motor HAT that also breaks out GPIO pins:
Return to “Adafruit Raspberry Pi® accessories”
