Data Sheet for 30mm Square Pushbutton Switch
brad92103
Post by brad92103 »
Presales question: I need a data sheet with mechanical dimensions for this lighted 30mm square pushbutton switch:
https://www.adafruit.com/product/491#description. I am considering trimming it down to fit a specific application. Putting it next to a quarter doesn't cut it. lol I need to know what the 30mm dimension applies to. Specifically:
1) outer dimensions of the plastic bezel
2) outer dimensions of the white lens cap
3) outer diameter of the round threaded base and/or minimum inner diameter of mounting hole
