16mm Illuminated Latching Pushbutton
MrHeisenberg
Post by MrHeisenberg »
What size are the male pins on the back of your 16mm illuminated pushbuttons (e.g., 1442)? Both the switch and LED terminals appear to be similar in width, but the switch pins are much thicker than the LED pins.
Thank you.
adafruit_support_carter
Re: 16mm Illuminated Latching Pushbutton
The diagram on the product page:
https://www.adafruit.com/product/1442
shows 0.6mm for the button tabs. It shows the spacing for the LED tabs, but not their thickness for some reason. Is eyeballing them from the known 0.6mm button tabs OK?
MrHeisenberg
Thank you for the information. It appears I can use a 2.2mm female connector and tighten or loosen the 'grip' based on each thickness.
