Basic Fingerprint Sensor with Socket Header Cable Not Working
yipaud
Post by yipaud »
I am currently working on trying to use a fingerprint sensor with my Raspberry Pi Pico. However, the fingerprint sensor is not lighting up nor connecting to my Pico. The PID is 4690 and my order number is #2292968-4794941265.
I purchased this item on January 7.
Any help is appreciated.
error in connecting to Thonny and pico
IMG_4698 Small.jpeg (25.43 KiB) Viewed 45 times
product not lighting up when plugged into pico
IMG_4697 Small.jpeg (26.4 KiB) Viewed 45 times
image of product
image of product
Image Small.jpeg (29.91 KiB) Viewed 45 times
adafruit_support_carter
Re: Basic Fingerprint Sensor with Socket Header Cable Not Working
The yellow wire appears to be disconnected? That's the TX line.
https://www.adafruit.com/product/4690
Red is 3.3V power
Yellow is TTL Serial TX
White is TTL Serial RX
Black is Ground
yipaud
Post by yipaud »
We tried using the yellow cable, and the fingerprint scanner does not light up. It does connect to the computer but is unable to scan the fingerprint so there is no input accepted.
Image of fingerprint scanner not lighting up when connected
IMG_5784 Small.jpeg (30.06 KiB) Viewed 38 times
Screenshot of computer output where fingerprint is not detected even when finger is on the scanner
Can you post a closer photo of the board showing the pins being used:
Also post (or link to) the complete code listing for what is being run on the board.
