I am new to CircuitPython and it seems to be causing me some problems. I want the ability to execute Python code, upon pressing one of the keys, on the Macropad 2040. This should give maximum flexibility, when programming a key press to do something.
I made my change, at line 151, to the attached code.py file. Prior to making this change, I confirmed the syntax operates the same as in Python.
I made changes to the linux-firefox.py script (also attached), that should get the function "func" called, if the first button, on the keypad, is pressed. However, when I press the button, the keypad screen says "Code done running" and I have to reset the device, to do anything else.
What have I done wrong? Can anyone help?
Sincerely,
Vincent
Macropad 2040 ducky enhancement problem
- vincentlarsen
- Attachments
- linux-firefox.py
- (1.66 KiB) Downloaded 4 times
- code.py
- (8.1 KiB) Downloaded 5 times
- vincentlarsen
Re: Macropad 2040 ducky enhancement problem
After much playing, I have found the problem. For those wishing to add the functionality, here is what needs to be done:
First, remove the change I made on line 151 and 152 (if type(item).__name__ == 'function': and item()). As it turns out, when the last item is a function, the "for item in sequence:" statement fails (tough to tell what is happening, with such a small screen :)).
Second, before the line "if pressed:," enter the following four lines:
if type(sequence).__name == 'function':
if pressed:
sequence(macropad, time)
continue
I moved the logic, before the "if pressed:" line, because I don't want that line's "else" clause to get executed, on release. I also added the two parameters, to the function call, for convenience.
Enjoy,
Vincent
if pressed:
continue
Enjoy,
Vincent
