Basic questions about PyPortal display
dastels
Re: Basic questions about PyPortal display
Post by dastels »
Did you try the gc.collect()?
Another question is how much data is getting returned from the GET?
ghulse
Post by ghulse »
dastels wrote: Thu Feb 02, 2023 8:00 pm Did you try the gc.collect()?
Yes, I have gc.collect() in there just before the time.sleep.
As to your second question, oof! A lot of data as it turns out.
This particular url has data for about 20 buoys.
r = requests.get(noaa_url)
text = r.text
The error specifies the text = r.text line. So maybe I need to modify this to just grab the first 100 characters or so. (The data for the Cambridge buoy comes first). Otherwise, I need to use a different url that shows only the Cambridge buoy data. Which is what someone was suggesting on the NOAA Nbuoy on MagTag thread:
viewtopic.php?p=958619&hilit=boaa+buoy#p958619
dastels
Post by dastels »
That'll do it. If you can reduce the amount to data being returned, it will definitely help.
ghulse
Post by ghulse »
This new NOAA data feed provides the time in UTC format. Is there an easy way to convert this to local time?
dastels
Post by dastels »
The PyPortal class has a get_local_time method that takes a string indicating your city/country as a parameter, e.g. Your city and country, e.g. "America/New_York".
ghulse
Post by ghulse »
The NOAA url returns the time of last data collected, not current time. (It’s usually about 45 minutes before current time). Would I be able to feed this time to the PyPortal class for conversion to local time? (Before I dive down this rabbit hole)
dastels
Post by dastels »
I wonder....
what if you fetch the current time in UTC, as well as in local time, compute the difference and use that to offset the UTC time from the data. See io.adafruit.com/<your Adafruit IO usename>services/time
ghulse
Post by ghulse »
I solved all my problems by finding a different rss feed—one that contains only the Cambridge buoy data. The time is already in eastern time zone, so I don't have to try to figure out how to convert UTC. Then I tweaked the code so the display so it is somewhat readable. This updates every five minutes and no crashes for more than 24 hours. Thanks for all the help.
dastels
Post by dastels »
Awesome!
