Nevermind, my bad, I didn't realize the servo only had 120 degrees of motion!!I purchased 5 Batan B2122 feedback servos. I am starting out with them, just calibrating and I am finding that they (I have tried 2 so far) are starting at 25-30 degrees then continuing to 180 degrees. They are not starting at 0 degrees no matter what I have tried. I did the same very simple sketch with a non-feedback servo and it goes from 0 degrees to 180 degrees no problem. I cannot attach the video I made, below is the simple code I am using:
#include <Servo.h>
Servo servo1;
int servoPin = 9;
void setup(){
servo1.attach(servoPin);
void loop(){
servo1.write(0);
delay(1000);
servo1.write(90);
delay(1000);
servo1.write(180);
delay(1000);
SOLVED-Feedback Servo not starting at zero
- EBCrp
- adafruit_support_bill
Re: Feedback Servo not starting at zero
Try altering the optional min and max microsecond values in your call to attach().
https://www.arduino.cc/reference/en/lib ... vo/attach/
