RP2040 Swap chucks of code in/out of memory
blakebr
Post by blakebr »
Is there a way to unload chunks of CP 8.0.0 code like a .dll from a microcontroller like the RP2040 because of limited memory?
My solution would be to use a FRAM memory chip for all variables. A library that is called by all code chunks that defines the location in the FRAM where the variables can be found and
supervisor.set_next_code_file(CODE)
supervisor.reload() # Ctrl-C then Ctrl-D
to switch between chunks.
I think if you were to look up UGLY in the CircuitPython dictionary this method would be listed as #1.
Bruce
mikeysklar
Re: RP2040 Swap chucks of code in/out of memory
Post by mikeysklar »
Have you tried:
del sys.module[‘modulename’]
blakebr
Post by blakebr »
Mike,
No I have not! Emoji with joy and surprise. I didn't know it existed. Thank you.
So I assume:
define variables
import module_one
# module_one runs and does all its work.
del sys.module(module_one)
import module_two
# module_two runs and does all its work.
del sys.module(module_two)
etc.
Bruce
mikeysklar
Yes, that is the idea at least.
The syntax will be slightly different and I’m not sure that memory will be cleaned out entirely just because the module is dropped.
The syntax really does use array brackets not function parenthesis.
 sys.modules[module_name]
The memory clearing you will probably need to monitor with gc.mem_free() before loading the module, after loading the module and after deleting the module.
One final wrench I’d like to add is this is meant for deleting system modules (frozen and built-in) will it work for optional modules from the lib/ folder? Slightly unsure emoji with sweat beads.
blakebr
Post by blakebr »
Mike,
Sorry for the slow reply (not sorry). My new Canon MF264dw II printer arrived and I just HAD to set it up. I hope you understand. Emoji {Evil Grin}
No joy in Mudville. This is the code I am using.
gc.collect()
print(gc.mem_free())
import ir_adafruit
gc.collect()
del sys.module[ir_adafruit]
gc.collect()
time.sleep(100)
This is what REPL has to say for itself.
Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
NTP_Clock_code.py output:
35552
34656
File "NTP_Clock_code.py", line 169, in <module>
AttributeError: 'module' object has no attribute 'module'
Code done running.
Press any key to enter the REPL. Use CTRL-D to reload.
The del sys. line is where the error occurs.
Bruce
mikeysklar
A new printer is an exciting detour.
Trying the plural version.
del sys.modules[ir_adafruit]
https://docs.circuitpython.org/en/lates ... ys.modules
blakebr
Post by blakebr »
Mike,
It is not crashing any more. I'll take that. This is the REPL output.
35456
34560
34560
It doesn't give the memory back. I will try other stuff and get back to you.
Bruce
mikeysklar
Okay, slight variation based on this thread @ stackoverflow.
del ir_adafruit
gc.mem_alloc()
gc.mem_free()
blakebr
Post by blakebr »
Mike,
I had to add single quotes to the module name and gc.collect, then it worked. Here is the final code.
del sys.modules['ir_adafruit'] # Quotes added.
del ir_adafruit
gc.mem_alloc()
gc.mem_free() # Probably not needed
gc.collect() # Also added
time.sleep(10)
Here is the output to REPL.
35440
34544
35312
Thank you,
Bruce
mikeysklar
so no effect in actually freeing up memory is what I'm seeing? Just a bunch of command successfully running.
blakebr
Post by blakebr »
Mike,
No? I see a loss of 896 bytes with the load of the library. A recovery of 768 bytes with the code above. (I didn't show all the code where the library was loaded.) 128 bytes are still unrecovered. I assume a more complex library will show a better recovery amount.
gc.collect(); print(gc.mem_free())
import ir_adafruit
del ir_adafruit
gc.mem_alloc()
gc.mem_free()
time.sleep(1)
print(sys.modules)
Bruce
mikeysklar
Cool. It worked.
blakebr
Post by blakebr »
Yup!
