I'm trying to install the adafruit-python-shell on my Rasp Pi 3.
It seems to install OK, but then trying to run raspi-blinka.py, I get a message telling me that 'adafruit_shell' was not found.
pi@raspberrypi:~ $ sudo pip3 install --upgrade adafruit-python-shell
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: adafruit-python-shell in /usr/local/lib/python3.9/dist-packages (1.6.0)
Collecting adafruit-python-shell
Using cached https://www.piwheels.org/simple/adafruit-python-shell/adafruit_python_shell-1.6.0-py3-none-any.whl (8.0 kB)
Using cached https://www.piwheels.org/simple/adafruit-python-shell/adafruit_python_shell-1.5.0-py3-none-any.whl (7.7 kB)
Requirement already satisfied: Adafruit-PlatformDetect in /usr/local/lib/python3.9/dist-packages (from adafruit-python-shell) (3.40.2)
Requirement already satisfied: clint in /usr/local/lib/python3.9/dist-packages (from adafruit-python-shell) (0.5.1)
Requirement already satisfied: args in /usr/local/lib/python3.9/dist-packages (from clint->adafruit-python-shell) (0.1.0)
pi@raspberrypi:~ $ sudo python raspi-blinka.py
File "raspi-blinka.py", line 11, in <module>
raise RuntimeError("The library 'adafruit_shell' was not found. To install, try typing: sudo pip3 install adafruit-python-shell")
RuntimeError: The library 'adafruit_shell' was not found. To install, try typing: sudo pip3 install adafruit-python-shell
