Emitter / Collector pins proper connection in the 1.2 kit
madlynxx
Post by madlynxx »
Hello everybody,
Sorry if this newbie question has already been adressed somewhere in this forum.
Slight confusion here: on the PCB of Adafruit's 1.2 kit (blue version), the "EBC" marking next to the 4 PN2222A locations suggests that emitter pins are connected to the cathodes of the 4 IR LEDs. In the official schematic (tvbgone3sch.png) however, PN2222A collectors are (with emitters connected to ground).
All reproductions I have been making with various LED models (including the fantastic Osram SFH4544), connecting collectors to cathodes, work very well.
Just to remove any ambiguity about the PN2907A + 4 PN2222A combo, can anyone definitely confirm that NPN transistors' collector pins should connect to LEDs cathodes, emitter pins to ground, as shown in the schematic?
Thanks a lot!
dastels
Re: Emitter / Collector pins proper connection in the 1.2 kit
Post by dastels »
Yes, with an NPN transistor the collector connects to the LED cathode, emitter to ground That lets the transistor switch current flow through the LED on/off.
Why do the PCB markings suggest that the emitters are connected to the cathodes?
madlynxx
Post by madlynxx »
Thank you Dave for you answer.
About the "EBC" marking in the picture above, possibly a misreading on my part (as it's possibly not meant to indicate the PN2222A mounting orientation). Associated with the transistor TO-92 shape marking next to it, it suggests that the provided PN2222A have a "CBE" pinout, which is not very common, hence my question.
I may push the interpretation a little to far :)
Anyway, thanks for the collector / cathode connection confirmation!
dastels
Post by dastels »
OK. Yeah, that is odd. It should be CBE if it's referring to the transistor pins. Even so it's completely unnecessary since the outline is there.
Return to “TV-B-Gone Kit”
