I purchased 4x adafruit assembled datalogging shields for arduino with the battery and preformatted SD card you sell. I attached each of the 4 datalogger shields to my Metro AT328 and ran the CardInfo example sketch. I kept getting Initializing SD failed.
Used 3 different SD cards ( all purchase from adafruit preformatted) and different batteries. I checked and the card is inserted with the text upwards as displayed in the adafruit site. I changed the pin select to 10 and there is nothing else wired to the board so all the testing the error recommends checking are correct. I am running arduino ide 1.8.19.
Any ideas will be welcomed.
datalogger shield with Metro AT328 with Adafruit SD card cante
- mromero
- dastels
Re: datalogger shield with Metro AT328 with Adafruit SD card cante
Can you post clear photos of your shields?
- mromero
- mromero
No matter what i try i keep getting:
- mromero
If the 2x3 SPI pin connector is not installed could that be the problem?
- mromero
thanks
the missing spi connector was the issue.
thanks all
thanks all
- dastels
Yes, the missing 2x3 SPI connector is probably the problem. You either use the SPI connector (easiest) or the SPI connection jumpers.
