In addition to that i have a i2c connection between my mega 2560 and esp32 dev kit c v4 on (Mega sda 20 and scl 21).
The esp32 is connected to an BANNED 4 controller via bluetooth in order to transmit
the controller values to the mega to controll the motors.
My i2c connection works fine and i receive the data from my esp32 but as soon
as I want to run a motor I dont receive any data from my esp32 and i cant controll the motor.
The motors movement works also as soon as i remove the i2c connection from the esp32.
Mega code :
#include <PS2X_lib.h>
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include <SoftwareSerial.h>
#include <Wire.h>
const int I2C_ADDRESS = 0x10;
const uint8_t SDA_PIN = 20; // choose a different pin for SDA
const uint8_t SCL_PIN = 21; // choose a different pin for SCL
const int I2C_CLOCK = 400000; // I2C clock frequency in Hz
// create an instance of the PS2X class
PS2X ps2x;
Adafruit_MotorShield AFMS_TOP(0x63);
Adafruit_DCMotor *motor_top = AFMS_TOP.getMotor(1);
Adafruit_DCMotor *motor2_top = AFMS_TOP.getMotor(2);
Adafruit_MotorShield AFMS(0x60);
Adafruit_DCMotor *motor = AFMS.getMotor(1);
Adafruit_DCMotor *motor4 = AFMS.getMotor(4);
Adafruit_DCMotor *motor3 = AFMS.getMotor(3);
Adafruit_DCMotor *motor2 = AFMS.getMotor(2);
bool startMotor4 = false;
Serial.begin(115200); // start serial communication with Serial Monitor
AFMS.begin();
AFMS_TOP.begin();
motor->setSpeed(255);
motor4->setSpeed(255);
motor2->setSpeed(255);
motor3->setSpeed(255);
motor_top->setSpeed(90);
motor2_top->setSpeed(255);
Wire.begin(I2C_ADDRESS);
Wire.onReceive(receiveEvent);
Wire.setClock(I2C_CLOCK);
// initialize serial communication
// start serial communication with ESP32
void receiveEvent(int byteCount) {
if (byteCount == 5) {
int lStickY = Wire.read();
int r1 = Wire.read();
int r2 = Wire.read();
// as soon as this code block appears
// then the prints below are no more shown
if(r1) {
Serial.println("r1");
motor->run(FORWARD);
motor4->run(FORWARD);
} else if(r2) {
motor->run(BACKWARD);
motor4->run(BACKWARD);
} else {
motor->run(RELEASE);
motor4->run(RELEASE);
// end of problematic block
int cross = Wire.read();
int circle = Wire.read();
delay(10); // Add delay
Serial.print("LStickY: ");
Serial.println(lStickY);
Serial.print("R1: ");
Serial.println(r1);
Serial.print("R2: ");
Serial.println(r2);
Serial.print("Cross: ");
Serial.println(cross);
Serial.print("Circle: ");
Serial.println(circle);
#include <PS4Controller.h>
#include <Wire.h>
Wire.begin();
mySerial.begin(115200);
PS4.begin("e8:61:7e:47:83:30"); // replace with your PS4 controller's MAC address
PS4.setLed(0, 255, 0); // set LED to green
int lStickY = PS4.LStickY();
int r1 = PS4.R1();
int r2 = PS4.R2();
int cross = PS4.Cross();
int circle = PS4.Circle();
Serial.println("foop");
Wire.beginTransmission(I2C_ADDRESS);
Wire.write(lStickY);
Wire.write(r1);
Wire.write(r2);
Wire.write(cross);
Wire.write(circle);
Wire.endTransmission();
delay(50);
Am I doing or understanding something wrong?
