I successfully built and tested the Wave Shield v1.1. I’m a newbie to all this but was able to overcome two problems: 1) the Library issue where in WaveHC.h you have to change DVOLUME=0 to DVOLUME=1 and 2) the Wave Shield seems to not work at all with my older green board Arduino even though the same board seems to run other programs perfectly. I tested it with daphc.ino and it seems to work as advertised. Now I’m trying set up to run Play6_HC and I’m confused about the circuit that goes with it.
The description at https://learn.adafruit.com/adafruit-wav ... o/play6-hc says “We will use a function called check_switches() that goes through the 6 buttons (digital 14 through 20) to see if they have been pressed” and includes this code:
// enable pull-up resistors on switch pins (analog inputs)
digitalWrite(14, HIGH);
digitalWrite(15, HIGH);
digitalWrite(16, HIGH);
digitalWrite(17, HIGH);
digitalWrite(18, HIGH);
digitalWrite(19, HIGH);
My Uno has Analog In 0 – 5 and Digital I/O ends at 13. What does the circuit for Play6_HC actually look like?
Circuit question for Play6_HC
- mikeysklar
Re: Circuit question for Play6_HC
The analog in pins can also be used as digital pins. You will use the digital pin number for those which gets you access to D14 - D19.
If you have the necessary push buttons you can connect one end to the digital pin and the other to GND.
https://learn.adafruit.com/adafruit-ard ... tal-inputs
