I2C Trouble starting two buses QT PY
KJRC
Post by KJRC »
I am attempting to use two I2C buses on a QT PY RP2040 w/ Arduino IDE. I can get one bus to start. However, I cant seem to find the correct command(s) to start both Wire and Wire1 at the same time.
I tested my wiring with adafruit code successfully (I2CScan from the testbed). I just cant get my code to work. Please see below code.
include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
#include <Adafruit_MPL3115A2.h>
Adafruit_MPL3115A2 mpl;
Adafruit_MPU6050 mpu;
void setup(void) {
  Serial.begin(115200);
  delay(5000);
  while (!Serial) {
    delay(10);
  Wire.begin();
  delay(1000);
  Wire1.begin();
  // the MPL is wired to GPIO 24&25. I can see this one.
  if (!mpl.begin()) {
    Serial.println("Could not find sensor mpl. Check wiring.");
    while(1);
  //program always tanks here. The MPU breakout is on the STEMMA (GPIO22&23)
  if (!mpu.begin()) {
    Serial.println("Failed to find MPU6050 chip");
    while (1) {
      delay(10);
there is more to the code but it is not relevant as we never get that far...
I get the "Failed to find MPU6050 chip" in the serial monitor.
Thanks for any help
K
neradoc
Re: I2C Trouble starting two buses QT PY
Post by neradoc »
I believe you want to pass &Wire1 to begin(), so that it knows that it must use the other bus.
https://adafruit.github.io/Adafruit_MPU ... 506179144d
Like that:
mpu.begin(MPU6050_I2CADDR_DEFAULT, &Wire1)
KJRC
Post by KJRC »
Neradcoc,
Thanks much works perfect. Here is what I updated my code to to make it work....
#include <Adafruit_MPU6050.h>
#include <Wire.h>
void setup(void) {
  delay(5000);
  while (!Serial) {
    delay(10); // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("starting Wire");
  Wire.setSDA(24);
  Wire.setSCL(25);
  Wire.begin();
  Serial.println("starting Wire1");
  Wire1.begin();
  Serial.println("Wire Done");
  if (!mpu.begin(0x68, &Wire1)) {
    while (1) {
      delay(10);
Return to “Arduino”
