hello, thanks,
the key is blinking very bright green over and over.
i understand that this is expected behavior.
please, how to disable, very distracting
or how dim it to lowest possible level.
stop the bright green blinking
- dastels
Re: stop the bright green blinking
What are you talking about. What board? Lots of things have bright green LEDs and some of them blink. We're going to need some specifics.
- neradoc
Yes please tell us more.
Taking a guess, if that's your Neo Trinkey from the other thread, the green blinking every 5 seconds in Circuitpython means "code done running". You can have it not happen by making your code not stop with this at the end:
That would normally be the loop of your code doing things and waiting for inputs or something like that.
You can also dim the status LED by adding this in a boot.py file:
Possible values range from 0 to 255, the default is 63.
while True:
pass
import supervisor
supervisor.runtime.rgb_status_brightness = 10 # or 0
- asdffdsa6132
- asdffdsa6132
