Feed Value size is limit not increasing
- Corey673
I change my feed history to off for the increased value size my published feeds are cut short when viewing them on the feeds page, I don't know what to do to get it to publish in full
- jwcooper
Re: Feed Value size is limit not increasing
The data is very likely being saved properly, but we are truncating on the UI in order to conserve space.
You could try creating a Stream block on the dashboard, as I think that will show the entire data sent. A few of the block should be able to show all of the data properly.
