I am trying to create an LED control based on the basic example. This is my first Adafruit.IO project and I was pleased with how easily everything came together. I was able to modify the code for my microcontroller and LED Strip. (I don't think it's relevant but using an AnaviTechnology LED Controller that uses the ESP8266).
The basic sketch is working great, and so I decided to add brightness and power controls as well. I got those working fairly quickly, but now I'm trying to get "fancy" and have the UX respond nicely to user input. For example:
- If the switch of "off" then brightness should be "0"
- if brightness is above 0 then "on-off" should be "on"
The code below creates an infinite loop which got my user temporarily banned (oops, did I mention I'm new here?)
I know it has to do with setting the state of both each time, I likely need to add a flag to control that, but wanted to ask for input before trying anything else since I want to be respectful of the API limits and ensure that my bad programming isn't gonna get me in any more trouble.
// Adafruit IO RGB LED Output Example
// Tutorial Link: https://learn.adafruit.com/adafruit-io-basics-color
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Todd Treece for Adafruit Industries
// Copyright (c) 2016-2017 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
/************************** Configuration ***********************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
// default PWM pins for ESP8266.
// you should change these to match PWM pins on other platforms.
#define RED_PIN 12
#define GREEN_PIN 13
#define BLUE_PIN 14
// set up the 'color' feed
AdafruitIO_Feed *color = io.feed("color");
// set up the 'on-off' feed
AdafruitIO_Feed *onOff = io.feed("on-off");
// set up the 'brightness' feed
AdafruitIO_Feed *brightness = io.feed("brightness");
uint8_t lastRed = 0;
uint8_t lastGreen = 0;
uint8_t lastBlue = 0;
uint8_t lastBrightness = 255;
// start the serial connection
Serial.begin(115200);
// wait for serial monitor to open
while(! Serial);
pinMode(RED_PIN, OUTPUT);
pinMode(GREEN_PIN, OUTPUT);
pinMode(BLUE_PIN, OUTPUT);
// connect to io.adafruit.com
Serial.print("Connecting to Adafruit IO");
io.connect();
// set up a message handler for the 'color' feed.
// the handleColor function (defined below)
color->onMessage(handleColor);
// set up a message handler for the 'on-off' feed.
// the handleOnOff function (defined below)
onOff->onMessage(handleOnOff);
// set up a message handler for the 'brightness' feed.
brightness->onMessage(handleBrightness);
// wait for a connection
while(io.status() < AIO_CONNECTED) {
Serial.print(".");
delay(500);
// we are connected
Serial.println();
Serial.println(io.statusText());
color->get();
// set analogWrite range for ESP8266
analogWriteRange(255);
// io.run(); is required for all sketches.
// it should always be present at the top of your loop
// function. it keeps the client connected to
// io.adafruit.com, and processes any incoming data.
io.run();
// this function is called whenever a 'brightness' message
// is received from Adafruit IO. it was attached to
// the brightness feed in the setup() function above.
void handleBrightness(AdafruitIO_Data *data) {
float brightnessVaule = data->toFloat();
float brightnessPercent = brightnessVaule * 0.01;
// print RGB values and hex value
Serial.println("Brightness Happening:");
//Don't do anything with brightness if the light is off
if( brightnessVaule == 0.0 ) {
if ( onOff->get() != 0){
onOff->save(0);
else{
if (onOff->get() != 1) {
onOff->save(1);
Serial.print("brightness: ");
Serial.print(brightnessPercent);
Serial.println("%");
analogWrite(RED_PIN, float( lastRed * brightnessPercent ));
analogWrite(GREEN_PIN,float(lastGreen * brightnessPercent));
analogWrite(BLUE_PIN, float(lastBlue * brightnessPercent ));
lastBrightness = brightnessVaule;
// this function is called whenever a 'on-off' message
// the on-off feed in the setup() function above.
void handleOnOff(AdafruitIO_Data *data) {
Serial.println("Power button clicked:");
//turn light off if zero
if( data->isFalse() ) {
Serial.println("Turning Lights Off:");
analogWrite(RED_PIN, 0);
analogWrite(GREEN_PIN, 0);
analogWrite(BLUE_PIN, 0);
if( brightness->get() != 0 ){
brightness->save(0);
else{
Serial.println("Turning Lights On to last color state:");
float brightnessPercent = lastBrightness * 0.01;
if( brightness->get() !=lastBrightness ){
brightness->save(lastBrightness);
// this function is called whenever a 'color' message
// the color feed in the setup() function above.
void handleColor(AdafruitIO_Data *data) {
lastRed = data->toRed();
lastGreen = data->toGreen();
lastBlue = data->toBlue();
analogWrite(RED_PIN, float(data->toRed() * brightnessPercent));
analogWrite(GREEN_PIN,float(data->toGreen() * brightnessPercent));
analogWrite(BLUE_PIN, float(data->toBlue() * brightnessPercent));
