I'm reading everything I can find but still feeling fuzzy on the meaningful difference between LoRa and RFM69 radios.
What I gather is that LoRa is proprietary and costs more for licensing, and has a 50-100% greater range thanks to clever frequency modulation.
Is there more to it, though? They both seem to support AES-128 encryption and addressable, multi-node data packet transmission.
My intended use case is very short range ( <10 feet, LOS) so I'm trying to figure if there's any reason to consider LoRa that I might be missing.
LoRa vs RFM69
Re: LoRa vs RFM69
That's all correct.pjforde1978 wrote: ↑Fri Feb 17, 2023 2:18 am What I gather is that LoRa is proprietary and costs more for licensing, and has a 50-100% greater range thanks to clever frequency modulation.
LoRa also has the option to connect to a gateway device (a computer with a radio and an internet connection). In theory you can have radio devices talking to each other from opposite sides of the planet as long as they're all within a kilometer of LoRaWAN gateways.
Nope.. for that kind of application, everything on the "LoRa can do X and packet radio can't" list will be useless.pjforde1978 wrote: ↑Fri Feb 17, 2023 2:18 am My intended use case is very short range ( <10 feet, LOS) so I'm trying to figure if there's any reason to consider LoRa that I might be missing.
- pjforde1978
Re: LoRa vs RFM69
Thank you so much! Perfect answer.
- Rcayot
Re: LoRa vs RFM69
I use the rfm9x and thi k it is great. The circuitpythonlibraries work well. I use a I use a Rpi PICO witha radio module and a bunch of sensors. I use a radio bonnet from Adafruit on my Pi4B to upload my IOT data to Adafruit IO. works great.
Roger
Roger
