I use this code for sending always "Enter" to my phone for a little app. I use button many time on days and when i don't use the button, i need to go in sleep mode my module to save energy. I want use with a Cell battery 2032.
I want to keep blutooth connection and just wakeup with a button action.
Somebody help for this ?
#include <Arduino.h>
#include <Adafruit_TinyUSB.h> // for Serial
Programmation d'un bouton qui envoie une ligne de texte sur la tablette
à l'aide d'un lien Blutooth. Attention au délai: 1 sec programmable
avec que la touche ne se répète. Dans le cadre d'un projet de production.
#include <bluefruit.h>
const int buttonPin = D1;
const int ledPin = D10;
#define SLEEPING_DELAY 30000
BLEDis bledis;
BLEHidAdafruit blehid;
int buttonState = 0;
bool hasKeyPressed = false;
void startAdv(void)
// Advertising packet
Bluefruit.Advertising.addFlags(BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE);
Bluefruit.Advertising.addTxPower();
Bluefruit.Advertising.addAppearance(BLE_APPEARANCE_HID_KEYBOARD);
// Include BLE HID service
Bluefruit.Advertising.addService(blehid);
// There is enough room for the dev name in the advertising packet
Bluefruit.Advertising.addName();
/* Start Advertising
* - Enable auto advertising if disconnected
* - Interval: fast mode = 20 ms, slow mode = 152.5 ms
* - Timeout for fast mode is 30 seconds
* - Start(timeout) with timeout = 0 will advertise forever (until connected)
* For recommended advertising interval
* https://developer.apple.com/library/content/qa/qa1931/_index.html
Bluefruit.Advertising.restartOnDisconnect(true);
Bluefruit.Advertising.setInterval(32, 244); // in unit of 0.625 ms
Bluefruit.Advertising.setFastTimeout(30); // number of seconds in fast mode
Bluefruit.Advertising.start(0); // 0 = Don't stop advertising after n seconds
void send_string()
int i = 0;
String send_data = "\n";
int number_of_data = send_data.length();
while (i <= number_of_data)
char one_alphabet = send_data[i];
blehid.keyPress(one_alphabet);
// Serial.print(one_alphabet);
i++;
delay(1000);
void setup()
Serial.begin(115200);
// Code pour attendre de démarrer le terminal série
// while ( !Serial ) delay(10); // for nrf52840 with native usb
Bluefruit.begin();
Bluefruit.setTxPower(4); // Check bluefruit.h for supported values
Bluefruit.setName("BT_IDS_001");
// Configure and Start Device Information Service
bledis.setManufacturer("Adafruit Industries");
bledis.setModel("Bluefruit Feather 52");
bledis.begin();
pinMode(buttonPin, INPUT_PULLUP);
pinMode(ledPin, OUTPUT);
/* Start BLE HID
* Note: Apple requires BLE device must have min connection interval >= 20m
* ( The smaller the connection interval the faster we could send data).
* However for HID and MIDI device, Apple could accept min connection interval
* up to 11.25 ms. Therefore BLEHidAdafruit::begin() will try to set the min and max
* connection interval to 11.25 ms and 15 ms respectively for best performance.
blehid.begin();
// Set callback for set LED from central
// blehid.setKeyboardLedCallback(set_keyboard_led);
/* Set connection interval (min, max) to your perferred value.
* Note: It is already set by BLEHidAdafruit::begin() to 11.25ms - 15ms
* min = 9*1.25=11.25 ms, max = 12*1.25= 15 ms
/* Bluefruit.Periph.setConnInterval(9, 12); */
// Set up and start advertising
startAdv();
void loop()
// read the state of the pushbutton value:
// Only send KeyRelease if previously pressed to avoid sending
// multiple keyRelease reports (that consume memory and bandwidth)
while (1)
buttonState = digitalRead(buttonPin);
if (hasKeyPressed)
blehid.keyRelease();
// Delay a bit after a report
delay(5);
if (buttonState == LOW)
digitalWrite(ledPin, HIGH);
delay(35);
digitalWrite(ledPin, LOW);
send_string();
hasKeyPressed = true;
delay(10);
