ADXL345 angle meter code doesn't work
idancrav
Post by idancrav »
anyone knows why this doesn't work?
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
#include <LiquidCrystal_I2C.h>
Adafruit_ADXL345_h adxlSensor = Adafruit_ADXL345();
LiquidCrystal_I2C lcdDisplay(0x20, 16, 2);
unsigned long timer = 0;
  Serial.begin(9600);
  lcdDisplay.begin();
  lcdDisplay.backlight();
  Wire.begin();
  adxlSensor.begin();
  Serial.print(F("ADXL345 status: "));
  if(adxlSensor.begin()) {
    Serial.println(F("Success!"));
  } else {
    Serial.println(F("Could not initialize ADXL345!"));
    while(1); // stop the program here
  Serial.println(F("Calibrating ADXL345, please wait..."));
  adxlSensor.calibrate();
  Serial.println(F("Calibration done!\n"));
  int xAccel, yAccel, zAccel;
  adxlSensor.readAccelerometer(&xAccel, &yAccel, &zAccel);
  if ((millis() - timer) > 100) {
    timer = millis();
    lcdDisplay.clear();
    lcdDisplay.print("X: ");
    lcdDisplay.print(xAccel);
    lcdDisplay.setCursor(8, 0);
    lcdDisplay.print("Y: ");
    lcdDisplay.print(yAccel);
    lcdDisplay.setCursor(0, 1);
    lcdDisplay.print("Z: ");
    lcdDisplay.print(zAccel);
    delay(10);
sj_remington
Re: ADXL345 angle meter code doesn't work
Post by sj_remington »
Please explain "doesn't work". What did you expect to happen, and what happened instead?
The code should display acceleration values. To calculate tilt angles, some math is required.
adafruit_support_carter
Also, what is the liquid crystal display being used? What Arduino library is being used with the display?
Return to “Arduino”
