What does it mean when CPG shows Red and Blue?
Play with it! Please tell us which board you're using.
TechEd
Post by TechEd »
My class has been working with CPG and MakeCode the last few weeks. We noticed some programs start and then the CPG goes to a mix of blue and red LEDs and stops operating. What does this mean? It is usually the same pattern and I have tried multiple CPG devices....... I can attach a picture if helpful showing the blue red pattern..... D13 small red LED is flashing also...
dastels
Re: What does it mean when CPG shows Red and Blue?
Post by dastels »
What are you calling a CPG? Sounds like a CircuitPlayground Express if you're using MakeCode.
TechEd
Post by TechEd »
Yes - circuit playground express.
TechEd
Post by TechEd »
dastels
Post by dastels »
What code are you running? A screenshot of the block code is probably good as long as it's readable.
TechEd
Post by TechEd »
A screenshot will have to wait a few days until I have the students back in class. I will add that this has happened with several different groups using different programs. Does the red/blue combo denote a programming/code error?
dastels
Post by dastels »
I'm looking into it.
adafruit2
Post by adafruit2 »
thats an internal error code - something 'crashed' inside of makecode. best bet is to post the code. sometimes this happens when people do wierd things with servos or detaching/attaching pins
TechEd
Post by TechEd »
Many thanks. One additional bit, maybe helpful, maybe not, the students have been using the temperature sensor and corresponding MakeCode blocks …… if temperature in F is greater than loops…
I don’t know if that’s pertinent.
adafruit2
Post by adafruit2 »
we'd really need to see a screenshot of the code to be able to know whats happening
petespaco
Post by petespaco »
Just out of curiosity, could you load (or have you loaded) any programs that don't do that?
Maybe some Ardino IDE sample.
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
