MMA8451 Accelerometer Data
matthewtrue
Post by matthewtrue »
Hey,
I am trying to track the vibrational movements of a transducer with an MMA8451. The code I have is below:
#include <Wire.h>
#include <Adafruit_MMA8451.h>
Adafruit_MMA8451 mma = Adafruit_MMA8451(); // Initialize MMA8451 accelerometer
const int sample_rate = 500; // Sample rate in Hz
const int sample_count = 1000; // Number of samples to collect
const float sensitivity = 0.063; // Sensitivity of MMA8451 accelerometer in LSB/g
  Serial.begin(9600); // Initialize serial communication
  while (!Serial) {
    ; // Wait for serial port to connect
  mma.begin(); // Initialize MMA8451 accelerometer
  mma.setRange(MMA8451_RANGE_2_G); // Set accelerometer range to +/-2g
  mma.setDataRate(MMA8451_DATARATE_800_HZ); // Set data rate to 800Hz
  float x, y, z;
  float max_x = -1000, min_x = 1000;
  float max_y = -1000, min_y = 1000;
  float max_z = -1000, min_z = 1000;
  unsigned long t1, t2;
  float freq, ampl_x, ampl_y, ampl_z;
  // Collect accelerometer samples
  for (int i = 0; i < sample_count; i++) {
    mma.read(); // Read accelerometer values
    x = mma.x * sensitivity; // Convert to acceleration in g
    y = mma.y * sensitivity;
    z = mma.z * sensitivity;
    // Update maximum and minimum acceleration values
    if (x > max_x) max_x = x;
    if (x < min_x) min_x = x;
    if (y > max_y) max_y = y;
    if (y < min_y) min_y = y;
    if (z > max_z) max_z = z;
    if (z < min_z) min_z = z;
    delay(1000/sample_rate); // Wait for sample interval
  // Calculate amplitude and frequency
  t1 = millis(); // Record start time
  freq = sample_rate / (float)sample_count;
  ampl_x = (max_x - min_x) / 2 * 9.81 * 1000; // Convert from g to mm/s^2
  ampl_y = (max_y - min_y) / 2 * 9.81 * 1000;
  ampl_z = (max_z - min_z) / 2 * 9.81 * 1000;
  t2 = millis(); // Record end time
  // Display amplitude and frequency on serial monitor
  Serial.print("Amplitude X: ");
  Serial.print(ampl_x, 2);
  Serial.print(" mm/s^2, Amplitude Y: ");
  Serial.print(ampl_y, 2);
  Serial.print(" mm/s^2, Amplitude Z: ");
  Serial.print(ampl_z, 2);
  Serial.print(" mm/s^2, Frequency: ");
  Serial.print(freq, 2);
  Serial.print(" Hz, Sampling time: ");
  Serial.print((t2 - t1) / 1000.0, 2);
  Serial.println(" s");
  delay(500); // Wait for 500ms before taking next measurement
The code is displaying outputs in the x,y and z axis are so wrongly incorrect. The frequency of the vibrations are not moving either...
Any help?
P.S. The movement should be around 1mm in the z, x and y are unknown. The frequency should be around 25Hz
Last edited by adafruit_support_bill on Thu Mar 02, 2023 5:31 pm, edited 1 time in total.
Reason: Please use [code] tags when posting code to the forums
Re: MMA8451 Accelerometer Data
Please post a sample of the output, and describe the motion it is subjected to and what you are expecting to see.
sj_remington
Post by sj_remington »
Keep in mind that the sensor measures the acceleration due to gravity, in addition to accelerations due to other forces.
If the motion is such that the orientation of the sensor changes, it is hard to see how this method could give useful results, because the components of g along each axis will be constantly changing.
matthewtrue
adafruit_support_bill wrote: Thu Mar 02, 2023 5:33 pm
I am expecting minimal movement in mm in the x and y directions, and movement from 0.01mm to 1mm in the z direction
matthewtrue
matthewtrue wrote: Thu Mar 02, 2023 8:50 pm
Screenshot 2023-03-02 184825.png (52.26 KiB) Viewed 169 times
matthewtrue
sj_remington wrote: Thu Mar 02, 2023 5:56 pm Keep in mind that the sensor measures the acceleration due to gravity, in addition to accelerations due to other forces.
Do you have any suggestions of a method that could give useful results? Thanks
sj_remington
It is common to use MEMS accelerometers in vibration analysis and there is plenty of literature on the topic. Here is one of the top hits using the search phrase: "vibration analysis mems accelerometer"
https://www.analog.com/en/analog-dialog ... oring.html
And another:
https://www.analog.com/en/analog-dialog ... ocity.html
matthewtrue
sj_remington wrote: Thu Mar 02, 2023 8:58 pm It is common to use MEMS accelerometers in vibration analysis and there is plenty of literature on the topic. Here is one of the top hits using the search phrase: "vibration analysis mems accelerometer"
And another:
Thanks for your help. I really appreciate this.
Return to “Arduino”
