I'm trying to run the spi flash examples, none of them are able to recognize the flash.
I'm using the latest libraries
adafruit_spiflash v4.0.0
sdfat v2.2.0
adafruit SAMD boards v1.7.11
arduino ide 2.0
SPI wasn't recognized so I used the custom SS and SPI. I tried both "SS" and "35" for the chip select
every time I reboot the cpx I get a different ID:
Adafruit SPI Flash FatFs Full Usage Example
Unknown flash device 0x0
Error, failed to initialize flash chip!
Unknown flash device 0xFF0005
Unknown flash device 0xFF0000
I must have the chip select wrong, or possibly the spi interface. Does anyone know?
what flash device ID should I expect?
CPX spiflash not working
- daverlee
Re: CPX spiflash not working
I got a little bit further. My CPX has an additional spi device sharing the data lines and I needed to hold that device's CS line high. now I can read the correct JEDEC code:
Flash chip JEDEC ID: 0xC84015
however, now if I try to format, I get this error:
Error, f_mount failed with error code: 13
I've tried erasing and reformatting, still get the same error.
- daverlee
I was finally able to get this to work by going back to the legacy arduino ide. I installed clean, spiflash worked right away. there's something wonky about circuit playground express and arduino 2.0
