ESP32 TFT 5483 - SPI versus I2C interface
salasidis
Post by salasidis »
I would like to know if the display is accessed via SPI (instead of I2C), and whether the SPI on the pins of the device can still be used (or it is reserved for the display). My guess is no based on the code below, but want to make sure. Thanks
void Adafruit_ST7735::commonInit(const uint8_t *cmdList) {
  colstart  = rowstart = 0; // May be overridden in init func
  pinMode(_rs, OUTPUT);
  pinMode(_cs, OUTPUT);
  csport    = portOutputRegister(digitalPinToPort(_cs));
  cspinmask = digitalPinToBitMask(_cs);
  rsport    = portOutputRegister(digitalPinToPort(_rs));
  rspinmask = digitalPinToBitMask(_rs);
  if(hwSPI) { // Using hardware SPI
    SPI.begin();
#ifdef SPI_HAS_TRANSACTION
    spisettings = SPISettings(4000000L, MSBFIRST, SPI_MODE0);
#else
#if defined(ARDUINO_ARCH_SAM)
    SPI.setClockDivider(24); // 4 MHz (half speed)
#else
    SPI.setClockDivider(SPI_CLOCK_DIV4); // 4 MHz (half speed)
#endif
    SPI.setBitOrder(MSBFIRST);
    SPI.setDataMode(SPI_MODE0);
#endif // SPI_HAS_TRANSACTION
  } else {
    pinMode(_sclk, OUTPUT);
    pinMode(_sid , OUTPUT);
    clkport     = portOutputRegister(digitalPinToPort(_sclk));
    clkpinmask  = digitalPinToBitMask(_sclk);
    dataport    = portOutputRegister(digitalPinToPort(_sid));
    datapinmask = digitalPinToBitMask(_sid);
    *clkport   &= ~clkpinmask;
    *dataport  &= ~datapinmask;
  // toggle RST low to reset; CS low so it'll listen to us
  *csport &= ~cspinmask;
  if (_rst) {
    pinMode(_rst, OUTPUT);
    digitalWrite(_rst, HIGH);
    delay(500);
    digitalWrite(_rst, LOW);
    delay(500);
    delay(500);
  if(cmdList) commandList(cmdList);
adafruit_support_mike
Re: ESP32 TFT 5483 - SPI versus I2C interface
The display is connected to the MOSI, MISO, and SCK pins at the edge of the board. It uses CS pins that aren't broken out to the sides of the board.
You can use the SPI pins for other devices, but you'll need to use other CS pins, and will need to manage which CS pins are pulled down when you want to talk to a given device.
Return to “Arduino”
