Wippersnapper library with wemos d1 mini pro
slaw54
Post by slaw54 »
Hi
Is it possible to use the esp8266 with the Wippersnapper library? I have a completely clean install of Arduino 1.8.19 with the only additional library being the wippersnapper one with all the additional required components also installed.
I get the following errors, do \i have to install the dallas temp file manually?
Thanks for you help.
Arduino: 1.8.19 (Windows 10), Board: "LOLIN(WEMOS) D1 mini Pro, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 16MB (FS:14MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600
In file included from C:\Users\Wally\Documents\Arduino\libraries\Adafruit_WipperSnapper\src/Wippersnapper.h:47,
from C:\Users\Wally\Documents\Arduino\libraries\Adafruit_WipperSnapper\src/network_interfaces/Wippersnapper_ESP8266.h:24,
from C:\Users\Wally\Documents\Arduino\libraries\Adafruit_WipperSnapper\src/Wippersnapper_Networking.h:25,
from C:\Users\Wally\Documents\Arduino\libraries\Adafruit_WipperSnapper\examples\Wippersnapper_demo\Wippersnapper_demo.ino:16:
C:\Users\Wally\Documents\Arduino\libraries\Adafruit_WipperSnapper\src/components/ds18x20/ws_ds18x20.h:22:10: fatal error: DallasTemperature.h: No such file or directory
22 | #include <DallasTemperature.h>
compilation terminated.
exit status 1
Error compiling for board LOLIN(WEMOS) D1 mini Pro.
brubell
Learn User Page
Re: Wippersnapper library with wemos d1 mini pro
Post by brubell »
Hi, the wemos d1 mini pro is currently unsupported by WipperSnapper. However, the ESP8266 is supported by WipperSnapper so by following https://learn.adafruit.com/how-to-add-a ... persnapper you should be able to add it to WipperSnapper.
The DallasTemperature library is available in the Arduino library manager (by searching for the same name) or here: https://github.com/milesburton/Arduino- ... ol-Library
Return to “Internet of Things: Adafruit IO and Wippersnapper”
