Generic onMessage callback
jpasqua
Post by jpasqua »
I am considering moving from Blynk to AdafruitIO and would value some advice. I will be using the C++ library.
As I understand it, if I want to subscribe to a feed within a group, I use the onMessage function to specify a callback that will be invoked when the subscribed data is updated. The callback receives a AdafruitIO_Data object from which I can identify the feed, but not the group. This means I can't have a completely generic callback that decides what to do based on the group/feed info.
Think of my use case as a dynamic dashboard on a small standalone display. Group/feed names are not bound at compile time. The feed/group names are read from a JSON file at run time and may be updated through a web interface. I don't see a way to write a single generic onMessage handler since I don't know which groups/feeds I'm being supplied. I also can't set up callbacks statically in the code since I don't know how many group/feeds there will be.
I do have an option that I believe will work which is to create std::function instances for each group/feed that encode the group name, but that's kind of ugly and wasteful.
I may be missing something obvious or am thinking about the setup incorrectly. I would appreciate any advice.
brubell
Learn User Page
Re: Generic onMessage callback
Post by brubell »
Is this possible within Blynk? How are you structuring your code with their client library's callback methods - I know they also use Arduino/C++ ?
jpasqua
Post by jpasqua »
With Blynk you can issue an explicit read on an ID/virtual pin combo, as opposed to a notification callback. It wasn't a callback in that case. At least that's the way their API used to work before they upended everything and went a new direction. I prefer the callback notification model rather than polling periodically.
I could just forget about groups and fake them by making every feed name be GROUP_FEED. For example, if I was going to have a group named "IndoorWeatherStation" with feeds named "Temp", "Humidity", and "Baro", I could just flatten the name space and have three feeds named "IndoorWeatherStation_Temp", "IndoorWeatherStation_Humidity", and "IndoorWeatherStation_Baro". Certainly not ideal, but it would work I think.
jpasqua
Post by jpasqua »
For the time being I just forked the library and made the callback type a std::function. That way I can pass in class members or lambdas with captures to handle additional state. As I learn more about the library and the best way to use it, I may find a better way.
Return to “Internet of Things: Adafruit IO and Wippersnapper”
