Adafruit_GPS and Softwareserial no such file
vdw
Post by vdw »
I am stuck and would very much appreciate some help. Using the GPS hardware serial parsing example. It works fine in Arduino IDE but in Platformio, which I prefer to use, I get the following error.
In file included from src\main.cpp:2:0: //which is the #include <Adafruit_GPS>
.pio\libdeps\megaatmega2560\Adafruit GPS Library\src/Adafruit_GPS.h:60:10: fatal error: SoftwareSerial.h: No such file or directory
The whole spiel is,
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/megaatmega2560.html
PLATFORM: Atmel AVR (4.1.0) > Arduino Mega or Mega 2560 ATmega2560 (Mega 2560)
HARDWARE: ATMEGA2560 16MHz, 8KB RAM, 248KB Flash
DEBUG: Current (avr-stub) External (avr-stub, simavr)
PACKAGES:
- framework-arduino-avr @ 5.1.0
- toolchain-atmelavr @ 1.70300.191015 (7.3.0)
LDF: Library Dependency Finder -> https://BANNED/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 7 compatible libraries
Scanning dependencies...
Dependency Graph
|-- Adafruit GPS Library @ 1.7.2
| |-- SPI @ 1.0
| |-- Wire @ 1.0
|-- SD @ 1.2.4
| |-- SPI @ 1.0
Building in release mode
Compiling .pio\build\megaatmega2560\src\main.cpp.o
Compiling .pio\build\megaatmega2560\lib056\Adafruit GPS Library\Adafruit_GPS.cpp.o
Compiling .pio\build\megaatmega2560\lib056\Adafruit GPS Library\NMEA_build.cpp.o
Compiling .pio\build\megaatmega2560\lib056\Adafruit GPS Library\NMEA_data.cpp.o
Any ideas Please.
sj_remington
Re: Adafruit_GPS and Softwareserial no such file
Post by sj_remington »
Download the SoftwareSerial library and put it where PlatformIO expects to find it.
vdw
Post by vdw »
Unfortunately that does not seem to solve the issue.
Return to “Arduino”
