Mini Relay Code
hydrophyte
Mini Relay Code
Post by hydrophyte »
This question is from an older discussion that is now locked....
viewtopic.php?t=195223&start=30
I deleted a couple lines of the rtc code and got it to keep time correctly, but I still can't get the mini relay to work.
Here's the latest version. I'm certain the relay is wired correctly because I tried a simplified sketch with pinMode(12, OUTPUT); and got it to work...
#include <RTClib.h>
#include <Wire.h>
#include "Adafruit_HTU21DF.h"
RTC_DS1307 rtc;
int hours = 0;
int minutes = 0;
int seconds = 0;
Adafruit_HTU21DF htu = Adafruit_HTU21DF();
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <SPI.h>
#define TFT_CS        10
#define TFT_RST        9 // Or set to -1 and connect to Arduino RESET pin
#define TFT_DC         8
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
  Serial.begin(9600);
  if (!htu.begin()) {
  Serial.println("Couldn't find sensor!");
  while (1);
  tft.init(135, 240);
  tft.fillScreen(ST77XX_BLACK);
  tft.setTextColor(ST77XX_CYAN);  // set text color to green and black background
  tft.setTextSize(2);
  tft.setRotation(3);
 /* rtc.begin(); */
  if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    Serial.flush();
    while (1) delay(10);
  if (! rtc.isrunning()) {
    Serial.println("RTC is NOT running, let's set the time!");
  float temp = htu.readTemperature();
  float rel_hum = htu.readHumidity();
  tft.setCursor(15, 15);
  tft.print("Temp: ");
  tft.print(temp);
  tft.print(" C");
  tft.setCursor(15, 45);
  tft.print("RH: ");
  tft.print(rel_hum);
  tft.print(" %");
DateTime now = rtc.now();
  tft.setCursor(15, 75);
  tft.print("Time: ");
  tft.print(now.hour(), DEC);
  tft.print(':');
  tft.print(now.minute(), DEC);
  tft.print(':');
  tft.print(now.second(), DEC);
if (rel_hum >=80) {
  digitalWrite(12, HIGH);
  tft.setCursor(15, 105);
  tft.print("Vent:");
  tft.setTextColor(ST77XX_RED);
  tft.setCursor(87, 105);
  tft.print("ON");
else if (rel_hum <=60) {
  digitalWrite(12, LOW);
  tft.print("Vent:");
  tft.setTextColor(ST77XX_YELLOW);
  tft.print("OFF");
 tft.setTextColor(ST77XX_CYAN); delay(5000);
Re: Mini Relay Code
Looks like you are using an Arduino UNO clone. Pin 12 is the MISO pin on the SPI bus. And you are using the SPI bus for your display, so the system will set that pin to INPUT mode.
You should choose a different pin for your relay control.
hydrophyte
Re: Mini Relay Code
Wow thanks a million. I wondered if the problem was the pin choice.
I'm using a Metro Mini. Looks like 12 is the MISO pin...
https://learn.adafruit.com/adafruit-metro-mini/pinouts
Re: Mini Relay Code
Yes. The Metro Mini is another ATMEGA328-based board. So you will need to avoid the SPI pins 11-13 if you are using SPI devices.
hydrophyte
Re: Mini Relay Code
adafruit_support_bill wrote: Thu Mar 09, 2023 8:34 pm Yes. The Metro Mini is another ATMEGA328-based board. So you will need to avoid the SPI pins 11-13 if you are using SPI devices.
Thanks again for helping me with this. I got a video up with the whole project...
https://www.youtube.com/watch?v=FWFufKJcUEk
Re: Mini Relay Code
Nice looking project! Thanks for sharing the video.
hydrophyte
Re: Mini Relay Code
adafruit_support_bill wrote: Wed Mar 29, 2023 7:25 pm Nice looking project! Thanks for sharing the video.
Thanks for watching! There's a second one up too also with microcontroller parts and a stepper driver....
https://www.youtube.com/watch?v=jQN_jVAZ6wo&t=12s
Return to “Arduino”
