Circuit Python
- Josefforsberg
Circuit Python
Does installing Wippersnapper disable circuit python? I'm very new to development boards and circuit python and I recently got a metro m4 express airlift. I installed circuit python on the board previously and tried out Wippersnapper today. I noticed that after connecting to IO that I could no longer create any code.py code and have it work. Thanks for any insight.
- dastels
Re: Circuit Python
Yes, both Whippersnapper and CircuitPython are firmware that gets loaded into the device's internal flash. You can only have one firmware (i.e. UF2 file in this case) installed/running at a time. Installing one replaces anything that was previously installed. If you want to use CircuitPython again, you'll need to reinstall the CircuitPython UF2.
