Music Maker featherwing
overlord73978
Post by overlord73978 »
I got a Music maker wing and a FeatherS2 recently. The Feather seems to work fine, I can drive neopixels with it, etc. But when I add the music maker, I can't get the wing to respond. I followed the tutorial in the Learn section, but getting no response. I'm getting the "Are you sure you have the right pins" error. I've verified all pins are soldered properly (using continuity check to second row of connection holes) and verified all pins on the feather as well.
Is there anything else I can do to try to verify if I have a bad board?
mikeysklar
Re: Music Maker featherwing
Post by mikeysklar »
Which example code and pins are you using? This would be the code to start and then figure out the pin customizations.
https://github.com/adafruit/Adafruit_VS ... player.ino
Even though the FeatherS2 is ESP32-S2 I suspect the default pins for the Adafruit ESP32-S2 boards will NOT work.
// Feather ESP32
#elif defined(ESP32) && !defined(ARDUINO_ADAFRUIT_FEATHER_ESP32S2)
  #define VS1053_CS      32     // VS1053 chip select pin (output)
  #define VS1053_DCS     33     // VS1053 Data/command select pin (output)
  #define CARDCS         14     // Card chip select pin
  #define VS1053_DREQ    15     // VS1053 Data request, ideally an Interrupt pin
overlord73978
That is the code I used, it's the arduino IDE example code. By throwing in a serial write, I was able to determine that this is the code being used and these are the pins.
// Feather M4, M0, 328, ESP32S2, nRF52840 or 32u4
#else
  #define VS1053_CS       6     // VS1053 chip select pin (output)
  #define VS1053_DCS     10     // VS1053 Data/command select pin (output)
  #define CARDCS          5     // Card chip select pin
  // DREQ should be an Int pin *if possible* (not possible on 32u4)
  #define VS1053_DREQ     9     // VS1053 Data request, ideally an Interrupt pin
mikeysklar
You are on the right track narrowing it down to those CS pins that are being used. Looking at the FeatherS2 pinout diagram and comparing it with the Adafruit Feather ESP32-S2 might help with selecting different CS pin numbers to try:
https://feathers2.io/
https://cdn-learn.adafruit.com/assets/a ... 1649709383
