I've been playing with the SPI on the Scorpio RP2040, and I've run into what I think is a documentation bug.
According to Table 2 of the RP2040 datasheet (https://datasheets.raspberrypi.com/rp20 ... asheet.pdf), GPIO 15 is SPI1 TX and GPIO 8 is SPI1 RX. That matches the green (SPI) and yellow (GPIO) annotations on the pinout picture. But it disagrees with the grey (CircuitPython) annotations, and with the silkscreen on the board itself.
Experimentally, the RP2040 datasheet and the green and yellow annotations on the pinout picture seem correct (MOSI/RX on GPIO8, MISO/TX on GPIO15), and the grey annotations and silkscreen seem backwards.
pinout documentation bug on Scorpio RP2040?
- seb_kuzminsky
- Attachments
- adafruit_products_feather-rp2040-scorpio-prettypins.png (398.5 KiB) Viewed 47 times
- alpierce
Re: pinout documentation bug on Scorpio RP2040?
It’s the same as the regular RP2040 Feather I believe. MOSI(MO) is an Output (TX) pin , and MISO(MI) is an Input(RX) pin. The pin function is with respect to the microcontroller and will be reversed on the peripheral, same as traditional UART serial interface. Maybe I am misunderstanding your perspective?
- seb_kuzminsky
Ah, thanks for clearing up my confusion. I'm using the RP2040 as the slave, but I understand now that the MOSI/MISO terminology is assuming the RP2040 is the master.
