RTC not keeping time. DS3231 STEMMA QT
JuanFR
Post by JuanFR »
I'm trying to set the time on the DS3213 STEMMA QT breakout connected to a kb2040.
I've set it up with circuitpython, no code on it yet, and i'm using serial console in Mu to set the time.
It has a brand new CR1220 that shows 3.2v over the VIN and VBAT pins when not connected to anything, no soldering done to the board yet.
This is what i'm using in REPL to set the time, but every time power is disconnected the time appears to be reset.
import rtc
import time
r = rtc.RTC()
r.datetime = time.struct_time((2023, 3, 15, 17, 12, 00, 3, 74, -1))
time.localtime()
i then get the correct output showing the time as:
struct_time(tm_year=2023, tm_mon=3, tm_mday=15, tm_hour=17, tm_min=12, tm_sec=19, tm_wday=2, tm_yday=74, tm_isdst=-1)
but after disconnecting the usb and rebooting the kb2040 i check the time in REPL with :
import rtc
import time
r = rtc.RTC()
time.localtime()
i get
struct_time(tm_year=2020, tm_mon=1, tm_mday=1, tm_hour=0, tm_min=0, tm_sec=38, tm_wday=2, tm_yday=1, tm_isdst=-1)
I've tried this on a macropad 2040 and a kb2040, am i doing something wrong or is my DS3231 dead?
Last edited by adafruit_support_carter on Fri Mar 17, 2023 1:37 pm, edited 1 time in total.
Reason: added [code] tags
Re: RTC not keeping time. DS3231 STEMMA QT
You're accessing the internal RTC:
https://docs.circuitpython.org/en/lates ... module-rtc
which probably does not have any power backup, and resets with each power cycle/reset.
See here for general code example for accessing the DS3231.
https://github.com/adafruit/Adafruit_Ci ... pletest.py
Also checkout guide:
https://learn.adafruit.com/adafruit-ds3 ... cuitpython
