Could I connect a tactile button switch to a QT Py ESP32-S2 WiFi without the use of a breadboard?
- Alkemist
I'm starting a project that would involve the QT Py ESP32-S2 WiFi board connecting to one or more adafruit tactile button switches. Could this be done without using a breadboard? Sorry if this is a bad question, I'm new to electronics.
- Franklin97355
Re: Could I connect a tactile button switch to a QT Py ESP32-S2 WiFi without the use of a breadboard?
You could solder the wires to the board if you want.
- Alkemist
Which pins on the board should I solder to? In the manual it doesn’t describe how to connect them?
- Franklin97355
You would solder them to the same pins you would connect the motherboard to. What manual are you talking about and how would you connect them using a breadboard?
