Ver. 8.1 Beta DHT11 not found issue
electromechpro
Post by electromechpro »
I have a Metro ESP32-S2 running 2 DHT-11 sensors on IO10 and 11, with an Arduino brand ethernet shield v2 acting as a datalogger for inside/outside temps. I was having no luck trying to add a soft-AP for monitoring it (remote site, no wifi), following the git hub and stack exchange threads. I tried installing CP ver 8.1 Beta, and still no AP love.
When I went back to my DHT datalogger code, the CP (8.1) code would not pick up the 2 DHT sensors (I was not able to figure which one or both, and swapped in a known good one at either location, no difference).
I then used the Adafruit web serial flasher and reverted back to 8.0.3, and with no code changes, the DHTs gave valid temperature readings.
I hope this is helpful, as I have received timely help with other issues I have had learning to work with Circuitpython.
P.S. I could really use some soft AP functionality in CP, as my instrumentation is not able to connect with a wifi network, and is often hard to physically access. My current Arduino code relies heavily on the "Cramazing" work of "My circuits" youtube video ESP32, SD and WiFi - Download/Upload/Delete SD files using ESP32 microcontroller as a web server.
danhalbert
Re: Ver. 8.1 Beta DHT11 not found issue
Post by danhalbert »
Would you mind opening an issue about this regression, with simple sample code? Thanks.
https://github.com/adafruit/circuitpyth ... new/choose
electromechpro
Will work on it.
electromechpro
4/3/23 Update:
CP Version 8.1 still gives a DHT not found error message on my Metro ESP32-S2 no matter which of several pins I use. I had used my Metro for some Arduino code experiments, and went back to CP and got the latest stable release from the website today. I used the Adafruit web serial flasher utility, erased first, then uploaded the 8.1 .bin to 0x00. No DHTs found.
I went back to 8.0.5 and was having trouble, so I went back to 8.0.3, where the code was last working.
The program ran on 8.0.3, but I may have had a wiring issue with the 8.0.5, and cannot confirm the DHT issue there.
danhalbert
The changes from 8.0.3 to 8.0.4 and 8.0.5 are unrelated to code that would cause this, so it sounds like an 8.0.x to 8.1.0-beta regression.
